What are your thoughts about this? Don't expect us to answer your homework questions for you. We expect you to show an honest attempt and then we will start from there and try to lead you to a correct answer.Why the carrier is always kept at least 10 times higher than the highest frequency of base band signal. Give explanation mathematically / numerically.
This is more of a useful "rule of thumb",& is not, by any means,universally applied.Why the carrier is always kept at least 10 times higher than the highest frequency of base band signal. Give explanation mathematically / numerically.
