All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-02-2012, 07:10 PM
rougie rougie is offline
Default Collector feedback bias...
hello,
wow...wow...wow
I did my first collector feedback bias circuit and I was impressed as to how close the measured and calculated values were. See attached file.
BUT THEN.... I swapped the transistor with another one with the same part # and wooops!
The Ie was now 1.36ma and Vc was 3.74!!!
I can't believe how volatile these things really are!!!!
But I guess this circuit is alot more stable that the simple base bias one!
Okay... I will now learn the other 2 types!!!!
thanks guys!
r
  #2
Old 09-03-2012, 02:27 AM
#12's Avatar
#12 #12 is offline
Default
I think a 2 resistor base bias is more stable, as in, not depending on the gain of the transistor to decide the operating point. Eagerly awaiting you next post when you tell us what you have learned.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #3
Old 09-03-2012, 04:19 AM
Sensacell's Avatar
Sensacell Sensacell is offline
Default
The hfe or beta of transistors varies widely, in general, if your design requires a specific value of hfe to work correctly, it's not a very good design.
It's often kind of horrifying to see the data sheet spread of hfe and realize what this means for your design- for it to work correctly with such a huge spread of gain. For example, the 2N4123 data sheet says it goes from 50 to 200!
  #4
Old 09-03-2012, 07:56 AM
debjit625's Avatar
debjit625 debjit625 is offline
Default
Except for Voltage Divider Biasing all other biasing with negative feedback circuit for a BJT in common emitter configuration will be \beta dependent.
Note in Voltage Divider Biasing, the effect of \beta is less but its not obsolete
I will prefer you to use some simulator software to perform these experiments,before doing them in real.
LTSpice will be good.
http://www.linear.com/designtools/software
Good Luck
__________________
Debjit Roy
__________________
A man would do nothing,if he waited until he could do it so well,that no one would find fault with what he has done.
- CARDINAL NEWMAN
  #5
Old 09-03-2012, 10:58 AM
Default
One thing though, asides from showing better stability than
a feedbackless base bias common emitter circuit, there isn't
much use for this circuit .... Right?
As you said, I can't even control it !!!
Yes Indeed!
  #6
Old 09-03-2012, 11:21 AM
Default
I will eventually look into LTSpice...
Thanks for the heads up
  #7
Old 09-03-2012, 01:05 PM
MrChips's Avatar
MrChips MrChips is offline
Super Moderator
Default How to display a quote
If you wish to insert other people's comments into your post, use the QUOTE tag.
Instead of the </ and /> that you used, end the quote with [/quote].
Begin the quote with [quote].
For example:
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
  #8
Old 09-03-2012, 02:05 PM
DickCappels DickCappels is online now
Default
If you reduce the value of the (470k) feedback resistor to something like 47k, the collector voltage and current will be much less dependent on the current gain of the transistor.
If taken to the limit -that is shorting the base to the collector, it will be even more stable, but less useful :-)
The Following User Says Thank You to DickCappels For This Useful Post:
#12 (09-03-2012)
  #9
Old 09-03-2012, 03:31 PM
ramancini8 ramancini8 is offline
Default
The calculated emitter current for Hfe=200 is 1.35mA, and for Hfe=50 is .671mA. The Hfe varies by a factor of 4 while the emitter current only varies by a factor of 2. Drop Rb to 47K and the numbers are Hfe=200, Ie=1.97mA and Hfe=50, Ie=1.69. Hfe varies by a factor of 4 while emitter current varies by a factor of 1.16.
This shows the dramatic effect that feedback can have on DC stability, but the circuit gain is reduced proportionately. If the gain required is AC it can be restored by bypassing Rb with a capacitor. A popular configuration splits Rb with a bypass capacitor to control DC and AC gain.
The two resistor base bias is useless unless there is an emitter resistor involved. Take the Thevinin looking from the base to the junction of the two base resistors and you get one resistor in series with a source; no feedback.
  #10
Old 09-03-2012, 03:35 PM
Default
Quote:
Not true unless you are using emitter degeneration (an emitter resistor). What don't I see????
Tags
Related Site Pages
Section Title
Worksheet Class A BJT amplifiers
Worksheet Bipolar junction transistors in active mode
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Video Lecture Transistor Biasing - Transistors and Transistor Circuits
Textbook Transistor ratings and packages : Bipolar Junction Transistors
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook Meter check of a transistor : Bipolar Junction Transistors
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
DC bias leoss General Electronics Chat 5 02-12-2012 09:44 PM
transistor bias current dcd528 General Electronics Chat 4 07-29-2011 02:58 PM
give me idea to solve voltage bias telescopic opamp tel_amp lady Homework Help 0 08-22-2009 11:07 PM
Basic transistor bias q... sorry clam General Electronics Chat 12 11-23-2007 03:35 PM
AC Bias Oscillator Circuit (Cassette Tape Rec.) electronics_shamim The Projects Forum 1 05-08-2007 10:49 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
