What do you mean? All four subcircuits are available. Click on "place component", choose the 14016 and then choose subcircuit A, B, C or D in the small tabs that appear.1.) In the schematic i have to use 4016N. This part is not in database so i put MC14016BCP. This model is using pin 1, 2,13 as open pins and that's it.
My problem is that i need to use 10,11,12 also. How can i set/enable those pins ?
I'm not an expert, but I don't think you can enable those. So all threshold values are related to 15V. (CMOS_15) I didn't test it but 12V should be good enough to be recognized as a HIGH.2.) In other model - 40160N - VDD and VCC is set as hidden. How to change this ?. Reason why i want to change this is because i want to set VCC to 12V and on my schematics net i use different voltages ( 5,12,72).
Huby
