Our professor posted the solution to a problem and I really have a problem understanding it.
1. The problem asks us to adjust a capacitor to modify the sending end. I don't understand how can a circuit element modify the voltage source?
2. In the solution at some point (second line) it says Ic = ..... = jIc, and it continues with that assumption. How is that possible?
Is this problem and its solution accurate?
Thank you very much for your help!
problem and solution are attached
