All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-24-2012, 05:43 AM
niceguynorthwales niceguynorthwales is offline
Default dc brake for ac three phase motors
hello to all, new to this site.
i was hoping someone here could help, we have a machine with a three phase 415v 3 kw motor, the starter for the motor was fitted with some form of :homemade: dc brake, however the starter was practically demolished during a move.
i know there are ways of making your own dc brake, does anyone know the circuit and components required, we would be deeply grateful for any assistance.
thankyou
  #2
Old 07-24-2012, 05:47 AM
strantor's Avatar
strantor strantor is offline
Default
When you say DC brake, are you referring to an actual physical brake attached to the motor, like an eddy current brake, or are you referring to some sort of DC injection scheme?
  #3
Old 07-24-2012, 08:42 PM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
We had a machine with 50/100 hp, 3600/7200 RPM, 60/120Hz direct drive spindles that used a low voltage high current transformer feeding a bridge rectifier. When the spindle was commanded to stop, a timer circuit 1) insured drop out of main A/C contactor, 2)supply low voltage DC to two leads of the motor for a fixed time 3) drop out and release DC to motor. It was also interlocked to prevent attempts of starting the spindle during the braking cycle.
  #4
Old 07-24-2012, 10:07 PM
GetDeviceInfo's Avatar
GetDeviceInfo GetDeviceInfo is offline
Default
another application I've worked with saw arbors where a rectifier is connected across the lines in the motor terminal box. The DC pulls off a spring loaded brake when powered. On loss of power the brake brings the arbor to an accelerated stop condition.
__________________
I get all the news I need on the weather report
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet AC motor control circuits
Worksheet AC motor theory
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Brushless DC motor : Ac Motors
Textbook Synchronous Motors : Ac Motors
Worksheet DC motor control circuits
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Half-wave rectifier : Discrete Semiconductor Circuits
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Testing an Industrial AC and DC Variable Speed Drives NiCeBoY General Electronics Chat 13 12-08-2013 02:11 PM
appropriate DC motors to fit to a manual wheelchair guskenny83 The Projects Forum 2 06-02-2012 03:28 PM
DC motors changing servo frequency emzdanow Embedded Systems and Microcontrollers 1 04-30-2011 05:52 PM
PWM- DC speed Motors Tree1 General Electronics Chat 2 02-18-2011 08:11 PM
DC and AC Motors, Back emf shespuzzling General Electronics Chat 8 04-21-2010 06:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
