Stereo started smoking!!!!!!!
EarlAnderson
Joined Nov 13, 2011
166
Just a while ago my stereo started smoking. I took it apart to see what was wrong and i found 2 SV31 biasing diodes that werent heatsinked good. I thought forsure that this might be the problem but when i tested them with my multimeter, they tested okay. Should i go ahead and replace them anyway
wayneh
Joined Sep 9, 2010
17,498
Not yet, I wouldn't.
Can you tell where the heat or smoke came from? Post a picture if you can see anything you have questions about. Skilled eyes here might see something.
What was the stereo (you mean the receiver, right?) doing when it went up in smoke? Did it stop making noise, make funny noises?
EarlAnderson
Joined Nov 13, 2011
166
Before i noticed the smoke, i noticed that the right channel started humming and the left channel sounded perfectly fine
wayneh
Joined Sep 9, 2010
17,498
That's bad, sort of. It means it's not your power supply and is more likely your right channel pre-amp or output stage. You should check to see if your speaker wires (or speaker) might be shorted on that side. There's a chance the amp protected itself from damage, even though it got hot enough to make a bit of smoke, and might recover once the short is removed.
EarlAnderson
Joined Nov 13, 2011
166
Nope. The speaker wires arent shorted, however i dod notice a couple of lifted copper pads on the circuit board
nomurphy
Joined Aug 8, 2005
567
If you have the box open you can visualy check for burned components, but you can also use your nose to smell for things that overheated or burned (or at least determine an area for further investigation). Just make sure the unit is off when your nose is close to the board(s).
SgtWookie
Joined Jul 17, 2007
22,230
Well then, that would seem to indicate that you have a problem in your power supply.
And it's most likely that you have a shorted electrolytic capacitor.
wayneh
Joined Sep 9, 2010
17,498
Proceed with caution. It blew for a reason, and it probably wasn't the source of the smoke. But the good news is it may have protected other components.
DerStrom8
Joined Feb 20, 2011
2,390
I agree with Sgt. Wookie. When I read the post, the first thing that popped into my mind is electrolytic capacitors. When they blow, they let out a LOT of smoke. And when you mentioned that one of the channels started humming, it suggested to me that one of the electrolytics used to smooth the DC after the rectifier in the power supply was blown. Check the capacitors for bulges, holes, and cracks. Chances are that's where your problem lies. Again, a photo of the board would be most helpful here :)
Regards
EarlAnderson
Joined Nov 13, 2011
166
Yeah but im still trying to figure out what the problem is in the first place. I found a couple of lifted solder pads on one of the transistors on the board where i think the smoke came from.
EarlAnderson
Joined Nov 13, 2011
166
Regards
Ill be posting a bunch of pictures tomorrow. I live out in the country and have slow internet so ill have to post them tomorrow at work
EarlAnderson
Joined Nov 13, 2011
166
I have good news and bad news. Good news is that i found out what the problem is. Bad neas is is that it's a burnt resistor and i dont know what value it is
