All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-08-2012, 06:23 AM
phoebe_ phoebe_ is offline
Junior Member
Default DC Motor Speed Control using LDR
I found this simple circuit of controlling the speed of a DC motor using a potentiometer. I'm wondering if this could still work if I replace the potentiometer with an LDR. I have a variable voltage supply up to about 15V.
  #2
Old 07-08-2012, 09:30 AM
bertus's Avatar
bertus bertus is online now
Administrator
Default
The LDR would probably burn.
It can most likely not handle the current needed for the motor.
You could try to make a PWM circuit that reacts on the LDR.
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 07-08-2012, 11:55 AM
Junior Member
Default
Oh I see.. But why would the potentiometer work?
  #4
Old 07-08-2012, 12:04 PM
bertus's Avatar
Administrator
Default
They are using a rheostat, that is an high power potentiometer.
It is also strongly dependent on the current drawn by the DC motor.
Bertus
__________________
  #5
Old 07-08-2012, 12:31 PM
Junior Member
Default
How about this circuit? Would a regular potentiometer (10k or 100k) work?
  #6
Old 07-08-2012, 12:46 PM
bertus's Avatar
Administrator
Default
A 10K potentiometer might work.
A 100K potentiometer will not work.
The transistor needs a certain current as input to control the motor speed.
The 10K might already be on the border of a correct working of the circuit.
On the following page you will find some circuits for motor control:
Motor control
Bertus
__________________
  #7
Old 07-08-2012, 12:55 PM
Junior Member
Default
I only have some simple components such as resistors, capacitors, potentiometer, voltage supply, transistors, etc.. I don't have ICs so I can't use PWM. Could you suggest other ways of doing it aside from the Darlington pair?
  #8
Old 07-08-2012, 01:34 PM
bertus's Avatar
Administrator
Default
Can't you get hold of an 555?
If you can get one, you might want to look at this thread:
http://forum.allaboutcircuits.com/sh...ad.php?t=24028
Bertus
__________________
  #9
Old 07-08-2012, 05:53 PM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
Using a straight resistance based control scheme will waste lots and lots of power creating HEAT.
The circuit above uses transistors as a variable resistance to lower voltage. The designer used a 5 inch square chunk of aluminum heatsink material, with fins 1.7 inches tall. The fan was included to keep temperature down. Avg current for the device in use is 10-20 amps and that will result in a 160 degree avg. temp rise. at the transistor mounting points. It was used to provide a slow ramp up of power for bench testing of RC plane motors.(paraphrased from the original descriptions)
Using a PWM scheme with a 555 IC might prove to be easier to do than what you see above, AND it would save lots of power that can be used by the intended load.
__________________
I'm too old.
Tags
Related Site Pages
Section Title
Worksheet Digital-to-Analog conversion
Worksheet Open-loop opamp circuits
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Worksheet DC motor control circuits
Worksheet DC motor theory
Worksheet Potentiometers
Textbook Rate-of-change indicator : Dc Circuits
Textbook Potentiometer as a rheostat : Dc Circuits
Textbook Potentiometer as a voltage divider : Dc Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Researching the history/compatibility of 120v DC/AC utility power DMahalko General Electronics Chat 70 07-04-2012 06:14 PM
Converting variable AC control to variable DC optimist55116 The Projects Forum 3 12-01-2010 08:49 PM
Current/Voltage Control of DC Signal lekhanhvinh General Electronics Chat 2 10-22-2010 10:47 PM
help with choosing DC control AC output relay vijaybala85 General Electronics Chat 9 09-08-2010 12:53 PM
DC motor speed control mahmoud shendy General Electronics Chat 2 10-20-2008 10:19 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
