All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Notices
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-06-2012, 04:33 AM
moorejohn90 moorejohn90 is offline
Member
Exclamation IR LED for catching intruder.
Hi, I don't have experience with IR led. But I want to use it for catching intruder. I know the way of using laser pointer with light dependent resistor. Can I use IR led instance of laser pointer. And I also want to know it can give the strength of light as laser (normal LED can reach as laser light). Is there any way of using IR led for catching intruder (not including PIR, I know about it). I have seen infrared ray that is like laser but can't be seen with human eye in movies, how it is work.
  #2
Old 07-06-2012, 02:01 PM
t06afre's Avatar
t06afre t06afre is offline
Default
Sure it can be done. You will need one IR transceiver and one IR receiver. The principal will be much the same used in any IR remote control. As you may know this is the "Embedded Systems and Microcontrollers" will you be using a microcontroller in your project? However you can make this without any micro also
  #3
Old 07-06-2012, 04:52 PM
BMorse's Avatar
BMorse BMorse is offline
Default
you can also just get an IR Laser........
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #4
Old 07-07-2012, 09:39 PM
BillO BillO is offline
Default
Quote:
Yeah, a 100KW CO2 laser will keep the intruders to a minimum.
__________________
Bill
Facts just don't care if you ignore them.
The Following User Says Thank You to BillO For This Useful Post:
strantor (07-07-2012)
  #5
Old 07-08-2012, 03:08 PM
Member
Default
Hi, Thanks for all of your reply.
Tags
Related Site Pages
Section Title
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED as IR Photodiode tom66 General Electronics Chat 24 10-05-2011 10:15 PM
Trouble with IR emitting LED circuit The Humanzee The Projects Forum 45 03-26-2010 02:49 AM
3 channel RGB LED controller if IR Danno72 The Projects Forum 3 02-17-2009 12:47 PM
how to connect IR led to 555... TNT General Electronics Chat 7 05-29-2005 02:45 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
