All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-17-2004, 09:21 PM
Kenny Kenny is offline
Junior Member
Default
A few time ago I made a question about the design of transformerless power supplies, say: 3V, 6V, etc, with current limiter; however I didn't receive any good answer.
I understand the dangers about the use of such thing, but I ask: is it not possible to reduce the dangers by using properly current limiter components i.e. fuse?
I saw a topic about ACLed but I think that would be very useful if someone with the knowledge dissects that circuit and make a complete explanation about the theory behind of it and how to make it safe.
OTOH, is there any forbidden subjects? Because the only answers to my question were: donīt do it, buy an ac adapter, but the people saying this think that the only factor to consider is the price, but they donīt think that the size is also important, i.e.: can you
imagine a 1/4 inches size circuit that compounds 2 leds fed by a 2 inches size adapter?
Also, what is the problem about learning to design such power supply?
  #2
Old 12-18-2004, 01:47 AM
Battousai Battousai is offline
Default
You need to be more specific. Transformer-less power supply driven from what type of voltage source? Are you trying to produce an AC or DC voltage?
If you're trying to produce a DC voltage, use a Linear regulator.
__________________
The distance between insanity, and genius, is only measured by success
  #3
Old 12-20-2004, 06:00 PM
dragan733 dragan733 is offline
Default
As I understood you have to supply only LED diodes. If is so, then I give you in the attachment circuits to supply the LED
  #4
Old 12-21-2004, 01:35 AM
Xray Xray is offline
Member
Default
Quote:
There is an error in the diagram shown on the right side. I believe that you meant for the supply voltage to be 110 Volts. That would make sense based on the resistor value.
The major problem, of course, with transformerless power supplies is the electrical shock hazard. A transformer provides isolation in case a person should come in contact with any part of the circuit when his/her body happened to be grounded. There is a way to use capacitors in place of a transformer for low current applications, and if designed properly could also provide some safety from electric shock.
  #5
Old 12-21-2004, 09:46 AM
Default
Yes, the right diagram is for 110V~. I copied the left diagram and I forgot to change the voltage to 110V~ on the right diagram.
Yes, also one can use a capacitor to reduce the voltage, but for small curent that is a solution expensive. But from othe side the resistors warm, the capacitors not.
  #6
Old 12-22-2004, 02:14 PM
Brandon Brandon is offline
Default
Its very possible and very dangerous. Just because an fuse says its 500mA doesn't mean that a spike of 10 Amps won't go through it before it pops. I remember on a digital output control board I was doing a design spec on I ran the 1 Amps fuses at 1 amp for nearly a minute before they finally began to pop.
Additionally, your wall outlet can give you as much current as the breaker/fuses in your house will permit as well. So if you have a penny in there, you could zap the crap out of your self.
Transformers, even 1:1, are good to isolate you and your electronics from a potentially deadly situation. Lets take a simple example. Say you did your circuit will some awesome LEDs and power resistor. Both which are rated better than the wire in you walls. You LED shorts out. Since the wire in your wall is rated lower, you now have a fire inside the walls.. good by house. You put the 1:1 transformer then connect your LED. LED shorts out but now, the wall doesn't see it. The wall gives off it AC to the transformer seeing the same load. Rather, the wiring of your LED, transformer secondary winds, etc will burn out and then go open circuit leaving your house still standing.
So in the end it comes down to how much do you trust underpaid workers 30-60 years ago to install proper wiring in your houses? I know I don't. When I rewired my kitchen I found no reds, no blacks, only yellow wires.. for everything. ground, common and 2 phases of 110AC. Needless to say i didn;t know there we 2 phases at first and ended up wiring them together as they both read 110 VAC on my meter and a fireball out of the breaker box later with some melted wires I figured it out.
You can do it, just be very very careful.
Tags
Related Site Pages
Section Title
Textbook Transformer -- power supply : Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
HP Elitebook Power Supply trader007 General Electronics Chat 34 02-12-2014 05:43 PM
Troubleshooting an xbox 360 power supply. jdraughn General Electronics Chat 1 04-30-2013 08:06 AM
combining two 12v power supply ell The Projects Forum 6 09-27-2011 06:38 PM
Help with modification of power supply for LED lighting Bhante The Projects Forum 6 12-18-2009 07:12 PM
Switching power supply with a dead (0v) "low" side FalconFour The Projects Forum 8 01-08-2009 11:37 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
