All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Programmer's Corner
Notices
Programmer's Corner Discussion forum for all aspects of programming and software engineering. Any software programming language welcome: C, C++, C#, Fortran, Java, Matlab, etc.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-02-2012, 12:17 AM
irfan16 irfan16 is offline
Junior Member
Send a message via Skype™ to irfan16
Question PLC Ladder logic Analog programming for Analog Input
Dear All
I am facing difficulty in programming the PLC for analog input. I have analog input that varies from 0~5volt. I want to develop ladder logic so that for 2.5 volt at input output should activate alarm and at 5volt input another alarm at out put should be activated. I am using ABB PM571 PLC. Can anybody guide me how I develop the ladder logic for above stated requirement.
I shall be thankfull to you.
Kind Regards
Muhammad Irfan
Student
  #2
Old 07-02-2012, 01:00 AM
strantor's Avatar
strantor strantor is offline
Default
I'm not familiar with ABB software, but look in your instruction set and find a comparator function.
  #3
Old 07-02-2012, 01:51 AM
Junior Member
Default
Can you send me any example. How I read analog input?
  #4
Old 07-03-2012, 02:18 AM
Junior Member
Default
Dear Sir
Can you send me example code.
  #5
Old 07-03-2012, 03:29 AM
strantor's Avatar
Default
No, I do not have ABB software. Sorry.
  #6
Old 07-03-2012, 05:42 AM
panic mode's Avatar
panic mode panic mode is offline
Default
i never used ABB controller but the idea is the same:
- get software and manuals
- get part number of the analog input card and it's manual
- configure/map I/Os
- write program to read I/Os (may require enabling it, setting network etc depending on type of used I/O)
- use compare instructions to set bit when value is in certain range
- download program to controller and monitor...
quick check with google suggests that software can be CoDeSyS (you can get it for free) but this would require target files for ABB plc (not free). all manuals are on abb website. good luck...
  #7
Old 07-03-2012, 09:39 AM
Junior Member
Default
Dear Sir
I have alraedy install ABB software codesys and configure the inputs and outputs. But I am not familiar that how i develop code to read analog input? I just need guideline that what function or block I should use to read the status of analog input.
  #8
Old 07-03-2012, 09:45 AM
Junior Member
Default
Quote:
If you have example code for PLC of any brand (i.e Siemens,Mitsubishi,Omron etc) Please send it as I need just idea that how to read analog input status.
  #9
Old 07-03-2012, 09:46 AM
Junior Member
Default
Dear Sir
  #10
Old 07-08-2012, 01:43 PM
GetDeviceInfo's Avatar
GetDeviceInfo GetDeviceInfo is offline
Default
I'm not familiar with the system your working with, but I'd think that the converted input/output would resolve to a word or double word with simple address or tag, no different than any other I/O.
Take care with your wording. 'Status' has special meaning in this field.
__________________
I get all the news I need on the weather report
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for digital circuit competencies
Worksheet Electromechanical relay logic
Textbook Programmable logic controllers : Ladder Logic
Similar Threads
Thread Thread Starter Forum Replies Last Post
Analog differential input - how to make it measure 0V when floating esm. The Projects Forum 2 02-25-2012 01:05 PM
Analog DC input buffers steinar96 General Electronics Chat 4 02-05-2012 05:56 PM
PNP sensor PLC input to NPN PLC input derekpaul General Electronics Chat 4 01-01-2011 03:24 PM
pic16f877a display 7 segments with input from rs232 summeranson Programmer's Corner 0 03-31-2009 04:11 PM
Some minor mistakes in your 'Digital logic functions: LADDER LOGIC jsz Feedback and Suggestions 1 04-21-2008 08:43 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
