All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-10-2012, 05:42 PM
onlyvinod56's Avatar
onlyvinod56 onlyvinod56 is offline
Exclamation 1:1 transformer question reg:
IN brief,
I want to trigger a mosfet/igbt with a pulse train of duty cycle 30% with 50Hz frequency.
Does the 1:1 pulse transformer responds to this signal?
Should i require any driving circuit?
  #2
Old 06-11-2012, 11:36 AM
Default
Any small info about pulse transformer is enough to proceed my discussion.
160 views but not even a reply.
Anybody worked on rectifiers.......
It will be thankful...
  #3
Old 06-11-2012, 02:03 PM
wayneh wayneh is online now
Default
Quote:
This is because your needs are not clear. No one knew how to reply. Where's a schematic? What is a "pulse transformer"? Why did you ask about rectifiers? Why not just use the "normal" DIY solution of a 555 timer to provide your pulse train? More information will help people give you better answers.
A dedicated driver may not be needed at 50Hz, where the drive currents are not so large.
  #4
Old 06-11-2012, 02:21 PM
t06afre's Avatar
t06afre t06afre is offline
Default
I saw your first question earlier today. And it was unclear. So at that moment i did not have time engage me in it. To me it look like you are confusing the function of a thyristor or TRIAC with mosfet/igbt. So it would help if you clear things up.
  #5
Old 06-11-2012, 03:09 PM
lightingman's Avatar
lightingman lightingman is offline
Default
IN brief,
Proably not. They are designed for short pulses or higther frequency. You would be better off using an opto-coupler.
Dan.
  #6
Old 06-11-2012, 06:56 PM
Default
Quote:
Thanks....thats all i want.
and regarding the schematic you are asking.......
there are many circuits where i want to use this pulse transformer.
example: a 5 level diode clamped multi level inverter.
Total 16 mosfets, 8 on each leg. I cannot use that many opto couplers. Iwant to eliminate the isolated power supplies. i want to use pulse transformer for each mosfet.
  #7
Old 06-11-2012, 06:58 PM
Default
Quote:
Wahtever..... they need a triggering pulse which i want to isolate from the triggering circuit.
  #8
Old 06-11-2012, 06:59 PM
Default
Quote:
Dan.
thankyou lightingman
Tags
Related Site Pages
Section Title
Worksheet Design Project: Radio transmitter
Worksheet Bipolar junction transistors as switches
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Worksheet Design Project: Sensitive audio detector
Worksheet Advanced electromagnetism and electromagnetic induction
Worksheet Impedance matching with transformers
Worksheet Autotransformers
Worksheet Step-up, step-down, and isolation transformers
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ethernet Transformer question xkris General Electronics Chat 0 06-10-2011 03:41 PM
Quick transformer question bzzzt Homework Help 3 05-20-2011 10:19 AM
Transformer power supply question DougB The Projects Forum 1 09-29-2010 05:00 AM
transformer question yoamocuy Homework Help 2 10-08-2009 07:56 AM
noob question about wire/fuse size on a transformer ynot General Electronics Chat 9 12-11-2008 01:15 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
