All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-07-2012, 07:00 PM
rudyauction8 rudyauction8 is offline
Question building step up circuit 12,000 volts - help!!!
I was wondering... I saw some 120-12.6 volt transformers at radiosnack, if I used 3 reversed in series, and used 12 volts AC to power them, would they give me ~12,000 volts or short out somewhere along the way. I am trying to make a circuit that generates small sparks. I was thinking a large one (~3 amps) first, then small ones (~1 amp) for the higher voltages. I know they aren't designed for high voltages, but would they work? They only need to last for a week or 2.
  #2
Old 06-07-2012, 07:14 PM
#12's Avatar
#12 #12 is offline
Default
Not work. The second transformer would be fed with 120 volts on its 12V winding. Fast smoke. Better to try the transformer out of an oil furnace ignitor.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #3
Old 06-07-2012, 07:23 PM
Default
Even though the 120 volts will only have a current of about 50ma? I was going to use a 500ma 12v AC power supply for this. If it will smoke out, then I may be out of options. I could also use single pulses of 12volt dc to reduce load. Or does it short out because the 120 volts goes through the insulation? I'm honestly more worried about the third, when 1,200 volts is fed into the 12 volt coil at something like 1-5ma.
Is it possible for me to make my own transformer(s)?
  #4
Old 06-07-2012, 07:27 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
Hallo,
There probably will also be problems with the isolation of the transformers.
It can be that there are sparks made INSIDE the transformers that may burn the transformers.
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #5
#12's Avatar
#12 #12 is offline
Default
You are correct to be more worried about the third stage. Whatever might go wrong with the second stage will surely go wrong with the third stage.
There are many ways to make a spark. Car ignition coil is one way.
It is possible to make a transformer, just much easier to find one that is already good enough.
Please describe your goal more fully.
Other helpers, please contribute ideas.
__________________
  #6
Old 06-07-2012, 07:41 PM
Default
my goal is a simple to build circuit that can generate sparks at least once per second that are about 1cm long, give or take. A car coil would work, but how does the circuit around it work, and how high of a voltage can I get from it? I would like to push what ever I use to the limit, if a car coil can give me 1 inch long sparks, that's what I will do. This circuit is just for fun, so the only restriction is the price. I can pick up a car coil at a junkyard today or tomorrow, but first, I need to know the details of how it works.
  #7
Old 06-07-2012, 07:54 PM
#12's Avatar
#12 #12 is offline
Default
I'd say a 555 timer oscillating at 1Hz with a low duty cycle, to a MOSFET that allows current through the low voltage side of the coil. When the MOSFET shuts off, a frewheeling diode allows the primary coil to collapse and the secondary coil kicks out a spark.
is that enough?
__________________
  #8
Old 06-07-2012, 08:03 PM
Default
I understand up to the diode. How and where does it go? I'm new with transformers. And how much voltage can I use? Could I use ~24 volts for a bigger spark? I have a few 18-30 volt power supplies from laptops to work with. Again, it only has to last a few weeks of 2-3 minute uses.
  #9
Old 06-07-2012, 08:08 PM
cork_ie cork_ie is offline
Default
AAC user DEBE has already done all the work for you here:
http://forum.allaboutcircuits.com/sh...ad.php?t=50728
You may need to vary the 555 timing to suit your needs
  #10
Old 06-07-2012, 08:19 PM
#12's Avatar
#12 #12 is offline
Default
I can't top that!
However, I can give you a dirty look for trying to up the voltage until you finally get it to fail.
__________________
Tags
Related Site Pages
Section Title
Worksheet Precise diode circuits
Worksheet Negative feedback opamp circuits
Worksheet Power conversion circuits
Worksheet Basic AC-DC power supplies
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Worksheet Superposition theorem
Worksheet Step-up, step-down, and isolation transformers
Textbook Operational amplifier models : Operational Amplifiers
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Rectifier/filter circuit : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
need circuit change 6 to 4 volts mrel The Projects Forum 5 07-19-2011 03:01 AM
Help on building a Boolean circuit Estudent1005 Homework Help 1 01-06-2011 07:35 PM
Submission: Sequential Circuits Georacer Feedback and Suggestions 17 10-31-2010 04:07 AM
Advice on building a circuit from an IR receiver to a modified mouse. avz10 The Projects Forum 9 05-16-2009 05:38 AM
Math Help with a Simple LED circuit fish4fun The Projects Forum 3 03-03-2009 04:04 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
