All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-02-2012, 02:06 PM
guskenny83 guskenny83 is offline
Default appropriate DC motors to fit to a manual wheelchair
hello, i posted this to the projects forum already, so apologies if posting here also is not allowed, but ive had 66 views on the other forum but no replies, so i thought i'd have more luck here..
im currently in my final year of a mechanical engineering degree and our final year project is to design and build a smart electric wheelchair, capable of being controlled by a person using only finger movements.
we have developed the control system using an arduino micro-controller, and integrated it successfully into a small-scale robot using two small 12V motors utilising a differential drive method of motion control, and a motor driver based on the L298N chipset from rcubestation.com:
http://www.rcubestation.com/r3cart/i...&product_id=75
my question is about the best way to now advance the project to a full-scale wheelchair.
having a mostly mechanical background, we have not covered that much material on DC motors, so i am looking for advice on the kinds of motors we should be looking to buy for this application, what kind of drivers we should use (im assuming the L298N is not going to be powerful enough) and any general advice people can give on motor attachment or any other aspect to do with the project.
As this project is not actually going to used by a disabled person for extended periods of time, and cost is a very large factor (we are only 2 poor uni students); the more economical, the better.
any information would be greatly appreciated
thanks
gus
  #2
Old 06-02-2012, 03:57 PM
Bernard's Avatar
Bernard Bernard is online now
Default
The remenants of an electric wheel chair had 2- 22V 250W motors with ? 7:1 gear reduction, & 10 in wheels. Rated @ 15 mph with 300 lb load. More than enough power. Homemaid control, 2 slide pots, manual rev. SW. 3 parallel MOSFETs each motor, PWM speed control. Was prone to blow FETs if speed advanced too fast- even with current control. Second version was never built.
  #3
Old 06-02-2012, 06:46 PM
BMorse's Avatar
BMorse BMorse is offline
Default
whats up with the multiple threads???? http://forum.allaboutcircuits.com/sh...ad.php?t=70781
I did respond in the other one
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #4
Old 06-03-2012, 12:22 PM
Rbeckett Rbeckett is offline
Default
A much larger stepper motor or servo motor is your next step. You will also need a much more powerfull driver board. The L293 and other inexpensive boards will not be capable of supplying the needed amperage. If you have not read DR Jones treatise on stepper motors, now would be a good time to review it. If you need a link or copy of that text LMK. If you are using Arduino then you are also using TTL or digital logic and will need an amp or driver to step up the power available to operate the relays or SSR's. Are you using any collision sensors like PIR or Ultrasonic? Probably should look to incorporate it into your over all design too. If you were to produce it commercially you will need passive and active safety systems to avoid a nasty product liability issue. Justa few thoughts from a wheel chair guy (I ride em, not build em). Hope this helps and if you need any additional texts for steppers and or servo I would be honored to share my fairly extensive library on this subject.
Wheelchair Bob
__________________
Doc, What exactly do you mean by "No Kidneys, dialysis and transplant"? I'm confused....Guess that means I have to drink less beer.....Right?
  #5
Old 06-03-2012, 02:11 PM
BMorse's Avatar
Default
Depending on the load the wheelchair may have to carry, you will need some pretty strong gearbox DC motors, preferably 24 volt ones. Like these ones on ebay http://www.ebay.com/itm/Invacare-WHE...b#ht_907wt_174
And the L298 WILL not handle these so you will need to have some kind of high current driver circuits, or a compatible H-Bridge circuit to control each motor, you can use the LMD18201T 3A, 55 volt h-bridges.
__________________
Tags
Related Site Pages
Section Title
Textbook Switch types : Switches
Worksheet AC motor control circuits
Textbook Synchronous Motors : Ac Motors
Textbook Introduction : Ac Motors
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook Contactors : Electromechanical Relays
Textbook Make your own multimeter : Dc Circuits
Textbook Analog and digital signals : Electrical Instrumentation Signals
Textbook Ohmmeter design : Dc Metering Circuits
Textbook What is a meter? : Dc Metering Circuits
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
