Linear power supply w/ multiple outputs
Trip1
Joined Jan 28, 2012
9
Hello, I am attempting to build a linear voltage regulated power supply with the following requirements:
-3 outputs:
  • 1 Variable 0-30Volts output up to 1A
  • + / - matched (tracked) output for powering various op-amps (up to 22V for ua741)
I have the following design that only does the first variable output, and I think this part of the design is pretty solid:
-Note that the second switch off the secondary of the transformer is basically used to control heat dissipation in the LM317. I will hit the switch when I need high current at low voltage to reduce the voltage drop across the regulator.
I'm wondering how I could modify this to include + / - supplies for powering op-amps. I want to be able to adjust them from say 15V up to 22V, and I want them to be tracked (adjust them both with 1 pot)
Would a second transformer be the best (easiest) solution?
38,550
What is the purpose of the two diodes in series with the output? They will just degrade the regulation of the regulator.
Here is a dual tracking regulator. It probably would be easiest to use another transformer for this circuit.
Trip1
Joined Jan 28, 2012
9
Thanks for the response. The two diodes in series with the output are a quick way of obtaining 0 Volts from the LM317.
How would the second transformer be wired in? Is there a way to do it so that the power supply would only require 1 plug?
38,550
You should use a larger diode than the 1N4007 for that purpose since it has a 1A max rating and you should not run any device. A larger diode will be more reliable and also have a lower forward resistance so the voltage change with load current will be less.
The voltage change from no load to full load will still be over a volt, if that's no problem(?). Remember that a diode forward drop versus current is logarithmic so you will still a small minimum output voltage at no load.
Just connect the two transformer primaries in parallel to the mains power through your switch and fuse.
mcasale
Joined Jul 18, 2011
210
You didn't give a load current for the dual supplies. If they are just driving a few op amps, you won't need much.
Here's a chip that might do what you want (SMT only, looks like) ...
http://www.linear.com/product/LT3032
There are fixed versions and an adjustable version.
With such a small load (?), I'd doubt you need a second transformer. Can you find one that has another set of secondaries? That might improve the heating you're going to get in the 1A supply.
upand_at_them
Joined May 15, 2010
939
I've seen a bunch of people talking about getting their LM317-based power supply to go down to 0V. What are people doing with it that they need to go below 1.25V?
takao21203
Joined Apr 28, 2012
3,702
They don't use LM317 for that.
Typically, OpAmp as error amplifier + pass transistor.
Reference voltage to one OpAmp input, and feedback to the other.
absf
Joined Dec 29, 2010
1,968
I think the polarity of LED D2 in the schematic is wrong.
Allen
