Is it possible to program over rs232(first time) on a AVR Development Board for Atmel
kubeek
Joined Sep 20, 2005
5,796
See http://www.lancos.com/siprogsch.html, the siprog is just a few zeners and resistors, and with true serial port works pretty fast, it programs the chip over the ISP header. With usb to serial converter it works too, but is very slow.
I use it too for programming I2C eeproms and other stuff, very versatile.
edit: you can forget d1,d2,d3 c3,c12,c4 and u3 since you will have normal power supply anyway.
rigers_21
Joined Mar 16, 2012
Hello
1.Thanks for the replay, i have now have borrowed a AVR dragon, and have got connected over Jtag :), will try to fix the bootloader(any hint about this?)
2.i Alsow have borroved a AVRISP MK2, can i use this? (i think so, but the connector on that one, dosen't fit my board(there is 6 pins on the AVRIPS, which sould i use?")
best regards Ronny
