All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-12-2007, 08:13 PM
bobank bobank is offline
Junior Member
Default 10 sec. countdown timer with LED display
Is any simple circuit available for countdown timer to start from no more than 10 sec ( can start as low as 3 second and go down.) On 0:00 sec relay activates, It should be able to use 7 segments display. What I want to make is something like clap board for movie clips for sinhronizing cameras. ON flip of a switch, red display start from, let's say 3:00 SECONDS, When it comes to 0:00 secs, relay should be activated, on relay I could connect LED light so something will get both cameras visible signal for first frame. It can work without LED light and relay, but it is easier to notice light than read numbers. Thanks
Boban Klasnikov
  #2
Old 09-12-2007, 09:23 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
Is it for a bomb? Just kidding.
You can resort to a variety of TTL or CMOS chips, depending on what you wan't, or a PIC microcontroller instead. So, what tecnology do you have in mind?
Please give more details about this project. What are the requirements?
__________________
I love the smell of toasted transistors in the morning.
  #3
Old 09-12-2007, 09:42 PM
Junior Member
Default
No reqirements, just something to work. My skills in elecronics are the best when:
1. I come into the store and buy product, and/or,
2. get schematic and do soldering ( pretty good in that)
Plus, my free time is unlimited. I bought myself about 10,000.00 dollars electronic laboratory and all I do was to turn on air solder station when is cold in the winter. So, you can guess I live in US. All time spent working so I can afford to buy things that I will never use because I have to work.. That was long answer. The sort is: something that have red numbers and they go down till 0.
Thanks, boban
  #4
Old 09-14-2007, 11:09 PM
Gadget Gadget is offline
Send a message via MSN to Gadget
Default
Bet that comment lit up the board at FBI headquarters...
  #5
Old 09-15-2007, 01:49 PM
mozikluv mozikluv is offline
Default timer
a cd4510 which is a cmos presettable bcd up/down counter, a cd4511 which is a cmos bcd 7 segment latch decoder and a 555 timer will do for you. plus a couple of transistors to drive your relay
moz
__________________
THE BIGGEST ROOM IN THE WORLD IS THE ROOM FOR IMPROVEMENT
  #6
Old 09-17-2007, 09:25 AM
Default
I'm guessing if it's for a Clapper Board, your gonna want 100th of a second divisions..... i.e. 10.00 down to 00.00 seconds.
That will require cascaded counters, and probably a slightly more accurate timebase than a 555.
A Micro based solution may be tidier, and more compact.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
15 second digital timer mrgthreepwood The Projects Forum 5 08-23-2007 11:52 PM
7 Segment LED display noltex The Projects Forum 17 08-08-2007 07:10 AM
Need help with an LED countdown Lost_Thought The Projects Forum 5 05-14-2007 03:23 AM
LED Dimming in Parallel pfhorge The Projects Forum 6 02-27-2007 07:36 PM
Can I use a 555 timer for this project? Bubblehead The Projects Forum 2 02-20-2007 04:33 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
