Synchronous Motor speed
mnada
Joined Apr 5, 2012
26
Hi Dear Friends,
The speed of the synchronous Motor is given by the equation:
s=120 x f/n where
s = speed in rpm
f = frequency
n = no of pole (here starts the confusion)
My confusion starts with the n (no of poles) whether it refers to the no of poles of the stator windings or no of poles of the rotor winding, and if it refers to the stator no of poles, does that meant that the no of poles of the rotor has no effect on the speed.
If so what is the effect of the increasing the no of poles of the rotor ( and what is the restriction of the no of poles rotor)
From wikipedia entry on synchronous motors:
Synchronous speed
The "synchronous speed" of a synchronous motor is the rate of rotation in RPM of the stator magnetic field.
The speed of the motor is a result of a combination of both stator and rotor. The stator field just sets the mark for the synchronous rotation speed.
mnada
Joined Apr 5, 2012
26
Thanks for your reply. Does that mean that n in the above equation refer to the number of poles of the stator?
What is the effect of number of poles of the rotor?
Yes, n will be the number of poles of the stator. A synchronous motor is synchronized when the rotor is rotating at the same speed as the magnetic field in the stator. When the rotor is rotating slower than the magnetic field in the stator, i.e. slip, torque is created.
Here is a small blurb from wikipedia again about the motor poles:
The number of rotor poles is typically less than the number of stator poles, which minimizes torque ripple and prevents the poles from all aligning simultaneously—a position which can not generate torque.
It comes from this page: http://en.wikipedia.org/wiki/Reluctance_motor
Just a really simple example.
t_n_k
Joined Mar 6, 2009
5,455
Overly trusting in Wikipedia can be potentially misleading.
Here's another quote from Wikipedia
Reluctance motors: These have a rotor consisting of a solid steel casting with projecting (salient) toothed poles, the same number as the stator poles.http://en.wikipedia.org/wiki/Synchronous_motor#cite_note-Fitzgerald-0
from
In any case when one has a two pole (per phase) synchronous motor then the rotor poles and stator poles must be the same.
mnada
Joined Apr 5, 2012
26
I quote the following from the lesson on synchronous motors:
"The three phases of stator excitation add vectorially to produce a single resultant magnetic field which rotates f/2n times per second, where f is the power line frequency, 50 or 60 Hz for industrial power line operated motors. The number of poles is n. For rotor speed in rpm, multiply by 60."
Regarding the rotating magnetic field speed is the red lined text correct?? I think it should be 2f/n, same synchronous speed?
t_n_k
Joined Mar 6, 2009
5,455
Yes you are correct - well spotted. You can report the error to the Feedback & Suggestions Forum.
