All About Circuits Forum
Go Back   All About Circuits Forum > Abstract Forums > Physics
Notices
Physics Discussion forum for anything physics related.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 05-09-2012, 05:54 PM
nsaspook's Avatar
nsaspook nsaspook is offline
Default
Quote:
Originally Posted by atferrari View Post
Navigation in a vessel turbine propelled is remarkably smooth. And much less noisy!
Usually, only when giving half or full astern you can say what the engine is doing.
Good for sleeping.
Vessels at sea also make for a good game of tag.
http://www.youtube.com/watch?v=N4jQh...eature=related
http://www.youtube.com/watch?v=SME4w037FgA
This will wake you up.
4X http://en.wikipedia.org/wiki/General_Electric_LM2500
__________________
We need a Check Up from the Neck Up.
  #12
Old 05-09-2012, 08:36 PM
strantor's Avatar
strantor strantor is offline
Default
Good for sleeping.
I served on a nuclear submarine. Yes, it is smooth, but I don't have much other experience in the way of vessels to compare it to. When we would go all ahead emergency, the boat would do what I can only describe as "peeling out in the water" - it would shake and vibrate and groan and moan. It was fun. Super quiet too. over a billion dollars worth of technology, I am aiming my sights a little lower. I have a feeling that any type of steam turbine (other than possibilities with hobby jet engines and car turbos) is going to require significant mechanical engineering and access to high level tools. The piston engine however is doable with what I have in the garage,
  #13
Old 05-09-2012, 09:16 PM
shortbus's Avatar
shortbus shortbus is offline
Default
Have you looked into "Tesla turbines"?
But the piston type engine is the way to go for a vehicle, no separate gear box/transmission required. A turbine needs to spin at much too high a RPM to be used without a high ratio gear box to slow it down to usable wheel speed. Even the ships use a final drive before the prop, right?
The biggest reason gasoline engines survived and steam died in cars was the time it took to get a head of steam up to start to move. Gas was instant and took over the car market. With the new flash steam generators and electronic controls it could be a whole new ball game.
  #14
Old 05-09-2012, 10:40 PM
nsaspook's Avatar
Default
Quote:
On US Navy gas turbine ships a double reduction gear shifts it down from about 14000 at the turbine to about 700 rpm on the main shaft with controllable pitch propellers that can adjust from full forward to full backward in seconds.
http://www.youtube.com/watch?v=lLSuWHvZzdU
__________________
  #15
Old 05-10-2012, 01:54 PM
russ_hensel russ_hensel is offline
Default
Efficiency in any heat engine is fundamentally limited by thermodynamics. For all cycles the higher the input T ( for a given output T ) the higher the efficiency. The Carnot cycle is the most efficient.
In practical situations the turbine often wins in large part because it can with stand higher inlet temperature.
  #16
Old 05-10-2012, 02:03 PM
Brownout's Avatar
Brownout Brownout is online now
Default
Quote:
Years ago, I read an article from a guy who built a steam trubo engine in his garage, using only good mechanical fabrication skills. He hammered out the "fins" -- for lack of knowledge of the proper term -- by hand. It was a single row of fins attached to a disk. He used it to power his DIY steam cleaner machine.
Maybe if you poke around a little, you might find the article archive or something similar. I forget where I read it; might have been Popular Mechanics or something like that.
__________________
My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. ~Hedley Lamarr
Tags
Related Site Pages
Section Title
Textbook Tesla polyphase induction motors : Ac Motors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wind Turbine Electronic Yaw Control canaryjohn The Projects Forum 8 04-12-2012 02:28 PM
Wind Turbine electrical braking system TomRij The Projects Forum 9 01-17-2012 01:11 AM
Wind turbine project... 3 phase rectifier-bldc motor controller Cbergerud The Projects Forum 2 12-23-2009 09:54 AM
wind turbine simulation in matlab sumitgupta The Projects Forum 3 07-17-2009 01:11 PM
Strange phenomanon with wind turbine! arthur92710 General Electronics Chat 5 04-22-2008 10:09 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
