74HC74 as inverter
ceidas
Joined Dec 26, 2011
50
so this is a flip flop and i want someone to tell if this truth table is correct or not.
D Qt Q(t+1)
0 0 1
1 1 0
0 0 1
Thank you.
Wendy
Joined Mar 24, 2008
23,797
Your drawing has two Q's. Normally I would assume Q' (Q not) in that position, in which case it would be a ripple flip flop (toggle on, toggle off).
Not sure what it would do with the Q output, don't think it would invert. Haven't thought about it.
WBahn
Joined Mar 31, 2012
32,942
I'm assuming you changed the drawing since Bill_Marsden's response. As you have it now (one DFF with D = Q') then I agree it matches your truth table, but I would not refer to it as an "inverter" - and inverter inverts the state of its input immediately, whereas this has no input and only acts on a rising clock edge. This is normally called a TFF (Toggle type Flip Flop).
t06afre
Joined May 11, 2009
5,934
Your schematic is a T flip flop. For each clock pulse. The output will toggle. To say this circuit is a inverter will not be correct I think
ceidas
Joined Dec 26, 2011
50
Ok, forget about the inverter. Can you tell me, how this truth table can be true? I mean since D=Q', if the truth table is true, then Q'=Qt. Is that possible?
WBahn
Joined Mar 31, 2012
32,942
My bad. I saw what I wanted to see and not what was written. I was too focused on the Qt and Q(t+1) entries.
You are correct. D should be opposite of Qt in the table. With a D FF, Qnext is always equal to D (unless a reset/set is asserted). So flip the D values in your table and you are good.
Wendy
Joined Mar 24, 2008
23,797
A flip flop changes states every time the input (the clock in this case) is toggled (changes states). Since a square wave is nothing but changing states, the output of a T flip flop will change states.
Think of a button, push on, push off, over and over.
It is the basis of all counters. There are other types of flip flops, but this one is basic.
The datasheet of a 4013 has a truth table, this is a dual type D flip flop.
Wendy
Joined Mar 24, 2008
23,797
Because your original drawing is a flip flop, and you are asking for a truth table. I gave you the truth table. You may not like the truth table, but it is what it is.
