All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-02-2012, 09:55 PM
liftupyourheads liftupyourheads is offline
Default Need help wiring cord to a 1.5 hp 115/230 volt motor!
I am completely new to electronics. I am a knife maker and I burned out my original motor for my belt grinder so I ordered another from ebay. When it arrived I was dismayed to find that there was no power cord attached! I've discovered that this is typical, however I have no idea how to wire a cord up to it and I don't want to mess up my new motor.
I was told that I need to figure out whether I want to run it on 115 volts or 230 volts but I don't even know which of those I want...
If anyone can help that would be AWESOME! I need this machine so I can continue making knives.
I was also wondering if I could use the old power cord from my burned out grinder?
thank you!
  #2
Old 05-02-2012, 10:42 PM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
What does the name plate on the old motor say? If it says 115/220 also, there should be a wiring diagram as part of the nameplate or under the cover where the cord goes in. How is the old motor wired?
  #3
Old 05-02-2012, 11:01 PM
MrChips's Avatar
MrChips MrChips is offline
Super Moderator
Default
Firstly, we'd better find out in which country you are living?
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
  #4
Old 05-02-2012, 11:06 PM
#12's Avatar
#12 #12 is offline
Default
I'm guessing USA because he has 115 available.
and yes, you can use the old cord if it isn't brittle or chewed up.
and this isn't electronics per se, but us electronic guys know how to do it.
So...read the label or post a photo.
I'm also guessing that reading the label will show how to fix this right up.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #5
Old 05-02-2012, 11:46 PM
strantor's Avatar
strantor strantor is offline
Default
greetings fellow bladesmith. I used a compressor motor for my belt grinder. Check it out. Won't be able to help you with yours until we see a pic of the nameplate.
  #6
Old 05-03-2012, 12:31 AM
MBVet05's Avatar
MBVet05 MBVet05 is offline
Junior Member
Send a message via Yahoo to MBVet05
Default
Generally, you have 3 wires going to the motor for ac. A hot, a neutral, and a ground. Just follow the wires from the plug to the motor like you would with an electric laundry dryer, or other such 3 phase wired equipment. Then just change out each wire one at a time. The other way that is easy for non electrical types is to mark the wires as they correspond to the motor and old cable and just match them up. Voila! If that is too confusing I am sure there are many DIY sites that have pics.
  #7
Old 05-03-2012, 12:51 AM
strantor's Avatar
Default
Quote:
I can think of a few ways that can go wrong.
  #8
Old 05-03-2012, 01:11 AM
BillB3857's Avatar
Default
Especially since this is single phase and not 3 phase and we still don't know if it is 115 or 220 volts!
  #9
Old 05-03-2012, 05:03 AM
CDRIVE's Avatar
CDRIVE CDRIVE is offline
Default Warning! This post contains extreme machine porn.
Quote:
This was enjoyable to watch because it's rare to have a face (in this case, a whole body) that to put on a handle. Jeff Foxworthy says there's a red neck in all of us just yearning to be set free.
Oh, you need one of these!
http://www.practicalmachinist.com/vb...allery-153748/
__________________
__________________________________________________ ___________________________
Disclaimer: Any information that I post is intended for educational purposes only. No warranty or liability is expressed or implied. Note: Working with household line voltages (Mains) can be dangerous. Proceed at your own risk!
  #10
Old 05-04-2012, 12:13 AM
strantor's Avatar
Default
I'd love to have an old lathe! Even more, room for one. And yes, the redneck is strong with me.
Tags
Related Site Pages
Section Title
Worksheet Summer and subtractor opamp circuits
Worksheet Step-up, step-down, and isolation transformers
Worksheet Basic troubleshooting strategies
Worksheet Batteries
Worksheet Temperature coefficient of resistance
Textbook Setting up a home lab : Introduction
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wiring help for a DC motor JonathanEngr General Electronics Chat 21 10-28-2011 08:47 PM
Simple three phase motor wiring question oidium45 General Electronics Chat 6 09-24-2011 05:38 PM
Wiring 56j 110/220 ao smith/Hayward pool motor etbrown4 General Electronics Chat 3 07-30-2011 11:15 AM
Wiring Help 230v ac 1phase motor shadowPDW General Electronics Chat 1 06-05-2009 10:31 PM
minn kota 12 volt trolling motor voodie General Electronics Chat 2 02-02-2007 09:16 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
