I am having a problem with my off grid wind generators. The "moderately" high winds in wyoming are wreaking havock on my turbines. I have burned up 12 turbines from the built in breaking action of commercial controllers and over speed.
I have a background in troubleshooting but not design. I am a technician not an engineer.
My system is 24 volts DC, 27 volts float, 28.4 volts Bulk charge. I would like to use this voltage variable to control an electromagnetic breaking device on the turbine rotor. with no application at 27.0 volts and adjustable application at 28 volts and higher to reduce turbine output and prevent over speed when the battery system has reached full charge.
This would have immediate commercial applications to which I have no interest. I would just like access to test and use the design.
The circuit should have adjustable input variables and adjustable output current.
I hope someone can help me with this challenge. Contact me with questions, I can provide pictures of the turbines i will use for testing and help with physical design. I can also help with concept.
Thank You
Thank You
