Simple Voltage Divider Algebra problem
ECE101
Joined Nov 25, 2011
29
1: Vout = Vin.R2 / R2 + R1
2: (R2 + R1). Vout = Vin. R2
3: (-R2. Vin + R2) + R1. V out = 0
4: R2(-Vn +1) + R1.Vout = 0
5: R2 = (R1.Vout) / (Vin + 1)
How does one go from line 2, to line 3?
I end up with:
3: (-R2. Vin) + R2. Vout + R1. Vout = 0
Could someone please explain?
hgmjr
Joined Jan 28, 2005
9,027
Loks like there is and error between line 2 and line 3 above.
I end up with:
Your result is correct.
hgmjr
ECE101
Joined Nov 25, 2011
29
So in terms of R2:
4: R2(Vout - Vin) + R1. Vout = 0
5: R2 = -R1. Vout / (Vout - Vin)
Is this correct?
If so how is the following derived here?
hgmjr
Joined Jan 28, 2005
9,027
All you should need to do is divide the numerator and the denominator by the value Vout. Remember that whatever you do the denominator, you must do to the numerator to perserve the equality.
hgmjr
ECE101
Joined Nov 25, 2011
29
Thanks again for the reply hgmjr
I'm still having a problem getting the wiki answer though!
3: (R2 + R1). Vout/Vin = R2
4: R2(Vout/Vin - 1) + R1(Vout/Vin) = 0
5: R2 = -R1(Vout/Vin)/(Vout/Vin - 1) ?
hgmjr
Joined Jan 28, 2005
9,027
I can see why.
The transition from 3 to 4 is a case of taking too big a bite. It should have been split up into two seperate steps.
hgmjr
hgmjr
ECE101
Joined Nov 25, 2011
29
Got it! Cheers:
Vout/Vin = R2/R1+R2
(R1 + R2) (Vout/Vin) = R2
R1 (Vout/Vin) + R2 (Vout/Vin) - R2 = 0
R1 (Vout/Vin) = R2 - R2 (Vout/Vin)
R1 = R2(Vin/Vout) - R2
R1 = R2((Vin/Vout) - 1)
R2 = R1/((Vin/Vout) - 1)
WBahn
Joined Mar 31, 2012
30,052
A couple of times now you have written:
Vout/Vin = R2/R1+R2
The second line doesn't follow from your first line, except when whoever is doing the work opts to replace the first line with what you meant to write and not what you actually wrote.
What you wrote is:
Vout/Vin = (R2/R1)+R2
Since division has precedence over addition. It's an easy mistake to make, which makes it all the more critical that you develop the habit of not making it very often.
WBahn
Joined Mar 31, 2012
30,052
Look at line 3 carefully. Do the units work out? No. The first term has units of volt-ohms while the second just has units of ohms. You can't add the two. You KNOW the equation is incorrect. There is no point even looking at what comes after it, because it is guaranteed to be WRONG (unless another error just happens to fix the first).
Having said that, let's look at what comes next. In equation three, you have (-Vn + 1). Most people, since they don't track units, won't be bothered by this at all because, being sloppy, they are used to seeing crap like this all the time. But, again, the units don't work. Vn (should be Vin, BTW) has units of volts and 1 is dimensionless and, if you were in the habit of tracking units, just seeing this would SCREAM out to you ERROR! ERROR! ERROR!
