The objective of this problem is to find Vo in terms of voltage magnitude and phase angle in degrees. Given: The current generator supplies 1 amp at 60 Hz and 0 degrees.
attempt:
If 60 Hz is given the voltage will be sinusoidal.
V = I * z
z = R + jx ( j is -sqrt(1)) (x is reactance)
using this converting x into ohms
x= 1/ (j* pi* f * C1) ( now in ohms)
KVL at far left loop:
0 = Vc1/(R+ 1/(j*2pi* f * C1) + I R4
with this I think you can find V@C1
Then KCL at far left node:
0= Vc1/1 + V4/4 - V1/R1
I am not sure how to attack the inductor. Please help.
attempt:
V = I * z
