All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-10-2012, 01:52 PM
cpakk cpakk is offline
Unhappy Home Wiring troubleshooting
Hi guys,
I live in India. Ac voltage here is 230V 50Hz single phase.
I had recently done wiring for my home for an sine wave inverter.
Inverter is installed and everything works.
I came across this weird problem after I got one of those led indicator spike guard (or extension sockets).
i got this Pinnacle spike guard (psg) today and was testing it. When connected to inverter power only it shows all ok.
When mains power came back, this is what i observed.
I had connected spike guard to ups. ups is connected to a) inverter line (through inverter) or b ) mains line (direct connection).
I had connected monitor and computer cable to the psg sockets and all switches on the psg were in off position. psg connected to ups which was off. ups connected to inverter line switch which was on.
I saw - All three lights were glowing a bit. Then i connected the ups plug to mains line and saw the same thing.
Next, i removed the plugged in comp and monitor from psg and surprise - only the ground led was glowing slightly (this is with ups button off). meaning ground is open (which is not true, because i recently had checked and rectified the wiring in my home)
touching the comp or monitor plug to socket gives same situation of all three lights being lit up (with ups still off). Putting the psg plug into mains without ups shows same behavior.
If ups is switched on, the 1st and 3rd led light up brightly whereas the 2nd led glows dimly.
I came to conclusion that this might be because, neutral is common throughout the house. so maybe some leakage current?
so it might be showing this type of behavior.
Also psg's internal circuits inside being messed up can be ruled out, because i didn't see this when mains power was not there (during load shedding).
The indicator led on the psg is given in this way: (Capital O = on)
LED1 LED2 LED3
O o O ----- all ok
o o O ----- neutral open
O o o ----- ground open
O O o ----- L & N reversed
O O O ----- L & N reversed & open
o O O ----- L & G reversed
  #2
Old 04-11-2012, 11:50 AM
Default
my previous wiring was according to diagram B in this thread. today i made it according to diagram A in the hope the fault goes away.
But no difference. i then checked from meter and saw that the wiring coming from meter is different compared to others meter.
seems like neutral and live is reversed in my meter.
Edit: what does Live & Neutral reversed and open mean? what should i search for exactly in my wiring to resolve this issue?
Tags
Related Site Pages
Section Title
Worksheet Opamp oscillator circuits
Worksheet Bipolar junction transistors as switches
Worksheet DC generator theory
Worksheet Series DC circuits
Textbook Parallel-in, parallel-out, universal shift register : Shift Registers
Textbook Programmable logic controllers : Ladder Logic
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Safe circuit design : Electrical Safety
Textbook Safe meter usage : Electrical Safety
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wiring diagram for conecting Home UPS to home electrical wiring kanoji_cb General Electronics Chat 20 09-24-2012 04:30 AM
Home Wiring Mystery rlfisher General Electronics Chat 10 12-29-2009 02:49 PM
Home DIY Subwoofer troubleshooting tips? Butterworth General Electronics Chat 11 05-08-2009 06:52 PM
Home Wiring Problem Aithne General Electronics Chat 1 09-07-2006 07:57 PM
Interesting Home Wiring Problem random24 General Electronics Chat 2 07-18-2005 12:03 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
