All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-30-2012, 06:49 AM
Jess_88's Avatar
Jess_88 Jess_88 is offline
Default 3phase double circuit trasmission line
Hey guys
I'm trying to work out this question, using an equivalent Pi circuit, but that fact that it is a "double circuit" is confusing me.
Here is the background.
A 3-Phase, 50Hz, 330kV, 360MW at 0.82 PF is supplied by:
-330kV, 50Hz, Length (L) = 160km, 3-Phase double circuit.
Each circuit has per-phase
Resistance (R) = 120x10^-6 per-unit/km
Reactance (X) = 990x10^-6 per-unit/km
Shunt Susceptance to Neutral (jB) = 461.7x10^-3 per-unit/km
Neglecting Shunt Conductance.
All units have been given in Vbase = 330kV, Sb = 100MVA
So what I think so far:
Because its a balanced and double
-both transmission line circuits will have the same voltage and current
-Thus we can calculate perimeters of just one line
But -The receiving current will be multiplied by two
Can I do these things?
Dose this effect the values used for each line impedance and the Shunt Susceptance?
With the Pi network
Z(line) = L x(R + jB)
=160((120x10^-6)+j(990x10^-6))
Do I need to convert this from phase resistance
I understand I may also need to determine the load impedance and add this to the line impedance for the equivalent circuit.?
What do you guys think?
thanks heaps
__________________
Give me a lever long enough and a fulcrum on which to place it, and I shall move the world.
-Archimedes
  #2
Old 03-30-2012, 11:35 AM
Jess_88's Avatar
Default
ok, so I have a little bit more direction i think.
theta = cos^(-1)(PF)
Ir(line-toline) = Pr/[(sqr(3)*Vr(line-to-line)*PF]
Because it is a medium length
A=D=(1 + (YZ)/2)--- p.u
C = Y(1+(YZ)/4) ---S
AD -BC = 1
Vs = AVr + BIr
Is = CVr + DIr
From my calculations, AD - BC = 1 seem to hold true. So i'm pretty sure that part is right.
But when I use
Is = CVr + DIr, I seem to get 85.86<89.702 (kA)
which seems way to big.
Am a suposed to do anything because it is a double connection?
__________________
-Archimedes
  #3
Old 03-31-2012, 10:27 AM
Jess_88's Avatar
Default
Can anyone confirm weather the equations I'm using for this circuit are correct?
__________________
-Archimedes
Tags
Related Site Pages
Section Title
Worksheet AC network analysis
Worksheet Series-parallel combination AC circuits
Worksheet Series and parallel AC circuits
Worksheet Phasor mathematics
Worksheet Trigonometry for AC circuits
Worksheet Impedance
Textbook Susceptance and Admittance : Reactance And Impedance -- R, L, And C
Textbook Series-parallel R, L, and C : Reactance And Impedance -- R, L, And C
Textbook Review of R, X, and Z : Reactance And Impedance -- R, L, And C
Textbook AC inductor circuits : Reactance And Impedance -- Inductive
Similar Threads
Thread Thread Starter Forum Replies Last Post
555 timer circuit for servos MoC General Electronics Chat 4 03-18-2010 12:33 PM
Simple line mixer circuit reevery The Projects Forum 2 06-23-2009 11:05 AM
Total Resistence in Parallel circuit AWSariti General Electronics Chat 14 02-27-2009 11:44 AM
LOW VOLTAGE Circuit TESTER lamps relicmarks General Electronics Chat 5 11-03-2008 12:32 AM
the term "common" shelly50 General Electronics Chat 27 01-23-2006 04:02 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
