Problem in Stepper Motor code (step angle)
theumer
Joined Mar 29, 2012
I need to drive a stepper motor that would rotate with a step angle of 7.5 degrees. The code that I wrote has an error even though I am unable to locate anything in the code. Here's the error:
Error [500] ; . undefined symbols:
_delay (stepper.obj)_digitalWrite (stepper.obj)_digitalRead (stepper.obj)_analogRead (stepper.obj)_pinMode (stepper.obj)
The code:
Rich (BB code):
#include <pic.h>
#define yellow 15  //Q1
#define orange 16  //Q2
#define brown 17  // Q3
#define black 18 // Q4
#define CW 33 // SW0 in schematic
#define CCW 34  //SW1 in schematic
void all_coils_off()
  digitalWrite(black, 0);
  digitalWrite(brown, 0);
  digitalWrite(orange, 0);
  digitalWrite(yellow, 0);
void reverse(int i) {
  while (1)   {
    digitalWrite(black, 1);
    digitalWrite(orange, 1);
    delay(analogRead(0)/4 + 10);
    i--;
    if (i < 1) break;
    digitalWrite(brown, 1);
    i--;
    if (i < 1) break;
    digitalWrite(yellow, 1);
    i--;
    if (i < 1) break;
    delay(analogRead(0)/4 +10);
    i--;
    if (i < 1) break;
void forward(int i) {
  while (1)   {
    i--;
    if (i < 1) break;
    i--;
    if (i < 1) break;
    i--;
    if (i < 1) break;
    i--;
    if (i < 1) break;
void setup()
  pinMode(CW, RB0);
  pinMode(CCW, RB1);
//  digitalWrite(CW, 1); // pull up on
//  digitalWrite(CCW,1); // pull up on
  pinMode(black, PORTC);
  pinMode(brown, PORTC);
  pinMode(orange, PORTC);
  pinMode(yellow, PORTC);
  // all coils off
void loop()
  if (!digitalRead(CW))
    forward(200);
    all_coils_off();
  if (!digitalRead(CCW))
    reverse(200);
    all_coils_off();
} // end loop
void main ()
 PORTC=0x00;
 PORTB=0xFF;
 setup();
 loop();
Any help would be appreciated.
John P
Joined Oct 14, 2008
2,063
It looks very simple. You've used a number of functions in your code which aren't recognizable to the compiler:
_delay
_digitalWrite
_digitalRead
_analogRead
_pinMode
t06afre
Joined May 11, 2009
5,934
It looks to me that you are trying to use some Arduino code in a Microchip MPLAB/HI-Tech C setting. You can not do that. But I am sure we kan help you out. As the code you posted should be easy to port
