Hello Mr. Marsden
My name is George. I am looking for a 555 I.C circuit alone to run 4 yellow LED`s in a chaser beacon setup. I run 1/16 R.C trucks and I would like to install a roof top safety warning beacon. The circuit has to be small so I thought, could the 555 alone handle 4 yellow LED`s on a 6v, 7.2v to a 12max. D.C battery source and the LED`s are about 20mA each. I would like to be able to have a variable resistor to adjust the rate at which the LED`s turn on and off.
Can you help me with this? Could you show me a circuit with the parts` list to do this?
Please let me know if you can help me with this.
Thanks for your time and consideration.
George
George
