All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-16-2012, 02:47 AM
DrWatts DrWatts is offline
Default Output Signal Swing of CE amplifier
Hey all, I ran into a wall while trying to design a common emitter amplifier. I was wondering if someone here would be able to point me in the right direction:
Specifications:
Common Emitter BJT amplifier with an Emitter Resistance and two coupling capacitors (assumed infinite for now)
Transistor 2N2222 (assume =100 and )
Design Goals:
Voltage Gain of -20 V/V
Output Voltage Swing ΔV=10V peak-to-peak
Input Resistance greater than 10kΩ
Attempt at Solution:
I thought to set to best bias the circuit. Thus . This would give a transconductance of .
Since the signal generator impedance is low:
The gain equation is . We can solve for . Which makes , , and .
I'm using a rule of thumb and making the current through the voltage divider equal to one tenth of the emitter current. Thus . Since the sum of the two resistances needs to equal and the voltage divider has to make , then and .
Finally, the collector current will be at a maximum when the amplifier is in saturation:
So by my math, the output signal should be linear up to 13Vpp. However, when I simulate this in SPICE (0.5V signal at 1kHz), my output signal is clipped above at 6.5V. I am sure that there is small mistake somewhere, but I have been unable to pick it out. I can provide more detail on how I derived my equations if necessary. Any suggestions on where to go from here?
P.S.: Sorry for the poor formatting, this is my first post!
  #2
Old 03-16-2012, 09:29 PM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
I don't believe you included the capacitor and the 47k load resistor in your calculations.
Keep in mind that the cap always has 7.5V across it. When the transistor cuts off, you are left with a series circuit between +15V and ground consisting of 10k, 7.5V, and 47k. This means that the peak current into the load is (15-7.5)/(10k+47k). Multiply this current by the 47k load resistance, and you get the peak output voltage.
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for analog integrated circuit competencies
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet Class A BJT amplifiers
Worksheet Bipolar junction transistors in active mode
Textbook BJT quirks : Bipolar Junction Transistors
Textbook Feedback : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Small Signal BJT Amplifier kaname08 The Projects Forum 27 03-09-2012 03:35 PM
Do guitar pedals draw guitar signal when there is no amp connected at their output? icydash The Projects Forum 25 07-05-2011 11:21 PM
Problem with output power-linear amplifier tzitzikas Radio and Communications 11 05-28-2010 10:15 PM
Help regarding audio amplifier.. sarang2502 General Electronics Chat 16 04-27-2010 10:16 PM
Television Aerial Signal Amplifier JUAN DELA CRUZ General Electronics Chat 17 06-03-2008 02:33 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
