All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-14-2012, 08:44 PM
jake077 jake077 is offline
Default How to draw timing diagram from logic gates???
hi, im learing about timing diagram with propagation delay but im having a hard time understand how to draw a timing diagram from expression/logic gates.
Here is a example:
F = A + (B*C), so A is OR with (B AND C). each gate having delay of 5 NS.How do i come up with a timing diagram for this? do i first make a truth table??? i mean where should i first start to tackle problem like this? thank
  #2
Old 03-14-2012, 08:58 PM
MrChips's Avatar
MrChips MrChips is offline
Super Moderator
Default
Yes, draw a truth table.
Next get some checkered or graph paper.
Draw voltage waveforms in time steps of 5ns.
Time is on the horizontal axis and volts on the vertical axis.
Draw three voltage waveforms, one each for A, B and C showing all eight possible combinations of A, B and C
Next show the waveform for (B AND C) taking into consideration a 5ns propagation delay.
Finally show the waveform for F = A + BC, again with a 5ns propagation delay.
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
  #3
Old 03-14-2012, 09:16 PM
Default
  #4
Old 03-14-2012, 09:17 PM
Default
this is a similar problem but i dont get where did they get the w to be 0 until 10 ns or how x is 1. Did they "assumed"???
  #5
Old 03-14-2012, 09:43 PM
Default
is this how to draw the waveform of each input like w,x,and y?? by doing the truth table
  #6
Old 03-15-2012, 12:00 AM
IronMod IronMod is offline
Junior Member
Default
I am actually working out of the exact same book as you for my Digital Systems class. Your functions of w,x, and y are already given to you in the problem. The truth tables he is referring to are for V, and Z, V will be the truth table for W and X (since W and X are an AND gate). Z will be the output of V and Y (OR gate). Look at page 225 and it should help explain to you how to read the graph.
Tags
Related Site Pages
Section Title
Worksheet Sum-of-Products and Product-of-Sums expressions
Worksheet Boolean algebra
Worksheet Performance-based assessments for digital circuit competencies
Worksheet Flip-flop circuits
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Series and parallel AC circuits
Textbook Serial-in/serial-out shift register : Shift Registers
Textbook Basic gate function : Digital Integrated Circuits
Textbook Diode switching circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Connecting logic gates JingleJoe The Projects Forum 17 01-06-2012 08:46 PM
Draw the logic diagram of the circuit. ITNetAngel Homework Help 7 07-12-2011 04:35 PM
Help - Draw the logic diagram for the following Boolean expressions. ajnsmt Homework Help 7 11-18-2010 03:14 AM
Drawing a Logic Diagram mcc123pa Homework Help 3 09-14-2010 01:03 PM
Digital Logic Gates susi General Electronics Chat 5 02-16-2008 12:34 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
