All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-12-2012, 10:49 PM
doug08 doug08 is offline
Default Transistor equivalent for bf494 & bc548
I decided to use ksp2222a to replace the bc548, and mpsh10 for the bf494. Let me know if you also think this is OK. My circuit does not work , and the transistors are definitely good(tested them).
  #2
Old 03-12-2012, 11:56 PM
Audioguru Audioguru is offline
Banned
Default
You forgot to post your radio (?) circuit so we don't know its frequencies.
  #3
Old 03-13-2012, 12:00 AM
Default The circuit operates at 100 - 150 mhz.
It is a small transmitter. I have no way to put it online. I don't have a scanner. I found it in an old electronics book.
  #4
Old 03-13-2012, 01:13 AM
Banned
Default
OLD, I know. I worked with the BF494 in 1969. It was the RF amplifier in an FM car radio.
If you cause interference with FM radios or with airplane communications then you will be in for BIG trouble.
  #5
Old 03-13-2012, 02:43 AM
Default
No worries with that stuff where I live. LOL. Back to my question, I looked at the spec sheets and it looks like the transistors I used should work. Do you agree or disagree. All I need to know. Thank You.
  #6
Old 03-13-2012, 01:58 PM
Default
I did some hunting for info, and yes, I was correct, you can use the mpsh10(rotated 180 deg) in place of a bf494(like I did). The bc548 > ksp2222a is also fine.
http://electronics-diy.com/electroni...tic.php?id=812
Tags
Related Site Pages
Section Title
Worksheet Switched capacitor circuitry
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Textbook The Silicon-Controlled Switch (SCS) : Thyristors
Textbook The Shockley Diode : Thyristors
Textbook IGBTs : Insulated-gate Field-effect Transistors
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook Class B audio amplifier : Analog Integrated Circuits
Textbook Transistor ratings and packages : Bipolar Junction Transistors
Textbook Thyristors : Solid-state Device Theory
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
