All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-22-2012, 04:41 AM
sinser sinser is offline
Default single phasing preventer
hi all , i am doing final project now , and m title is single phasing preventer , below is about my project.
Abstract:
Three phase motors and other appliances are widely used in all sectors of industry. these appliances are prone to damage to single phasing. Apart from damage the costly apparatus, it may also cause a production loss. The objective of this project is to design a single phase preventer.This circuitis meant for the 3 phase 1kW induction motor.
i have found a circuit , this circuit i can use for my project? here is the link
http://www.circuitsector.com/2010/12...r-circuit.html
i try to connect it in multisim but i cant complete it , anyone can help me connect the circuit in multisim and sent it to me?
or anyone have another circuit which is suitable for my title
  #2
Old 02-22-2012, 05:20 AM
Experimentonomen Experimentonomen is online now
Default
This is prolly considered "transformerless power supplies" and thus not allowed on this forum.
Either way i'd do it with three small transformers in star configuration with the center tap of the star connected to neutral, then feed the low voltage (5-12v) from each transformer to a triple input AND gate which when satisfied will close a NO contact in the control circuit, thus allowing the motor contactor to pull.
An example: http://i.imgur.com/RziVc.png
When tripped: http://i.imgur.com/vd8Ky.png
  #3
Old 02-22-2012, 06:14 AM
Default
can i know the transformers is step-down or ?
  #4
Old 02-22-2012, 06:31 AM
Default
thank you for the circuit.
can i have the link discuss about this circuit , because i need to know the working principle about this circuit and is this call single phasing preventer?
  #5
Old 02-22-2012, 07:17 AM
Default
My circuit will disconnect if either of the three phases drops out, i have never built this and i do not recommend using DIY circuits in industrial applications.
It works by using a triple input AND gate which as the name suggest need all tree inputs active(high) to give a active signal out. This signal can control a relay which you put inline with the power supply that produces the power that controls the motor contactor coil, beeing either 12v, 24v or 120-230v mains. If a phase drops out, the AND gate will detect this and shut off its output, and thus release the main motor contactor, preventing the motor from single phasing and burning out.
If this is for use in your own home, then you may build such circuit yourself, provided that you have the knowlege and training in electrical safety.
But if it is for a industrial application thats designed to run 24/7-365 for decades such as a conveyor belt or pump in a factory, then i'd advice you to buy a professionally made motor protector from a electrical supplies store and have a licensed electrician install it.
  #6
masosi masosi is offline
Junior Member
Default
Try looking for Phase Fail Relays.
Just an idea.
  #7
Old 02-22-2012, 07:26 AM
Default
can i know where can i get L1,L2,L3 and N in the software?
  #8
Old 02-22-2012, 07:47 AM
Default
You dont need them, some sim proggies come with a 3phase signal source, for those that don't, just use three single phase ones and phase shift them 120degrees from each other.
Tags
Related Site Pages
Section Title
Worksheet AC motor control circuits
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Single-phase power systems : Polyphase Ac Circuits
Textbook Special transformers and applications : Transformers
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Programmable logic controllers : Ladder Logic
Textbook Motor control circuits : Ladder Logic
Textbook Permissive and interlock circuits : Ladder Logic
Textbook Contactors : Electromechanical Relays
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Detecting single cell reversals in long series batteries Mr. Mik The Projects Forum 29 12-07-2010 10:40 AM
single ended amplifier circuit ybababababsma Homework Help 3 12-04-2010 03:23 AM
single supply op-amp jameselder232 General Electronics Chat 4 11-04-2010 06:32 PM
Three phase vs single phase rectifier questin DiBosco General Electronics Chat 5 09-09-2010 01:39 PM
TL084 Can work with single supply? cokolakare Homework Help 6 04-08-2010 03:51 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
