All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-21-2012, 02:08 PM
tom7891 tom7891 is offline
Junior Member
Default Charging small battery using wind?
Hi, i was just wondering if it's possible to charge a small battery with a small wind turbine? The turbine is just a coil of thin wire with a permenent magnet inside, the coil is only the size of a thumbnail.
When i test for voltage across the turbine i get no voltage, which i'm assuming is because of the resistance on the multimeter i'm testing it on. I'm guessing if it will charge the battery, it'll take a while?
The battery has around a 5v output. Sorry if i'm being vague, but i don't really know a lot about this. Any help would be appreciated.
  #2
Old 02-21-2012, 03:07 PM
Audioguru Audioguru is offline
Banned
Default
Use a DC electric motor that has permanent magnets inside. It makes a good generator.
Did you make the "turbine" yourself? Does it spin fast with lots of power when you connect it to a powerful battery? Or is it an AC turbine instead of a DC one?
  #3
Old 02-21-2012, 03:08 PM
Brownout's Avatar
Brownout Brownout is offline
Default
Multimeters usually have high resistance for voltage testing, so you can't blame it. There appears to be somethign wrong with your generator.
__________________
My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. ~Hedley Lamarr
  #4
Old 02-21-2012, 03:29 PM
Junior Member
Default
I nicked the turbine from a wind powered phone charger. I'm making a wind powered phone charger for a project at college, so i thought i'd use a turbine that was built for the job. It looks like a bridge rectifier is in the charger circuit, so looks like it's a dc turbine.
I've managed to get some voltage from it, but only 0.5v, and it fluxuates a lot.
  #5
Old 02-21-2012, 04:52 PM
Banned
Default
I have never heard of a "wind powered phone charger".
Does it charge the phone when you are holding it while sky-diving at 120mph?
  #6
Old 02-21-2012, 05:06 PM
Junior Member
Default
It's supposed to charge the phone when on a bike. Good idea though
  #7
Old 02-21-2012, 05:16 PM
Banned
Default
A year or two ago a kid wanted to use a little computer fan as a generator to charge the battery for his bike's lights. He didn't understand that it needs a huge windmill to produce enough power and the power comes from him pedalling harder, not from the wind.
  #8
Old 02-21-2012, 06:01 PM
hwy101's Avatar
hwy101 hwy101 is offline
Member
Default
http://www.envirogadget.com/odd-gadg...hones-concept/
  #9
Old 02-21-2012, 06:15 PM
Banned
Default
The "iFan" is a "Concept Design" from Holland where the wind blows like crazy!
The designer also talks about holding it outside a car window while driving.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
charging a 12v battery with a 36 volt Battery Bank. Possible? Easy or Hard? shutech General Electronics Chat 1 03-23-2011 05:49 AM
Charging current of 20 AH Battery kfrazie1 The Projects Forum 11 01-08-2010 07:21 AM
Solar panel battery charging hovik General Electronics Chat 5 11-06-2009 02:05 AM
battery charging circuit rakesh696 Homework Help 0 01-02-2009 05:56 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
