confused for analog to digital level adjustment
hardianta
Joined Nov 10, 2011
i have an oscillator from XR2206..
it oscilate at 900hz square,, now i want to divide the freq into 90 Hz and 150 hz,. i 've had the divider cct with jk flip-flop n dflip-flop. one i dont understand is how to adjust the level ofXR2206 to digital circuit...i use 74ls76 jk for divider,, help please
Felo
Joined Feb 20, 2012
91
Hi, the 4017 IC will make a nice divider for this, use the 6th output for 150hz and the 10th for 90hz, feed the 900hz in the clock input of the 4017 and there you have it!!
BillB3857
Joined Feb 28, 2009
2,571
I would double check the 4017 to give variable divisions without external gating. It is a basic divide by 10 counter with 10 decoded outputs. Any single output will simply divided the input frequency by 10.
djsfantasi
Joined Apr 11, 2010
9,163
Are you limited to using the ls76 jk flip flops for the dividers? You will need a divide by 10 for the first result and a divide by 6 for the second. These are implemented in the ls90 counter and ls92 counter ICs respectively. Otherwise, you will have to construct your own. Similar results can be obtained by using two 4017 ICs.
(BTW, this is a duplicate post RE: confused)
