All About Circuits Forum
Go Back   All About Circuits Forum > Abstract Forums > Physics
Notices
Physics Discussion forum for anything physics related.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-07-2012, 05:59 PM
amilton542's Avatar
amilton542 amilton542 is offline
Default Current ampacity for small swg conductors
I want to calculate the current carrying capacity of small copper enammelled wire guages.
Everything I look at is AWG, and their cross-sectional areas are too big. I'm after an swg table but can't find one.
Is there a formula I can use to determine the current ampacity?
  #2
Old 02-07-2012, 06:50 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
You can convert the SWG to AWG using the following table:
http://educypedia.karadimov.info/library/mech001.pdf
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
The Following User Says Thank You to bertus For This Useful Post:
amilton542 (02-07-2012)
  #3
Old 02-07-2012, 06:57 PM
amilton542's Avatar
Default
Thank you.
  #4
Old 02-19-2012, 07:46 AM
Kozmyk Kozmyk is offline
Default
A lot of the data in tables giving ampacity per wire size is application related. Mainly to mains power installation.
These include safety margins for heat dissipation, cable bundling, insulation melting points etc. and are not the maximum ampacities for a single conductor in free air.
The ultimate maximum would be at the point at which the conductor fails i.e. melts or breaks.
Clearly you have to work back from that state.
The Following User Says Thank You to Kozmyk For This Useful Post:
amilton542 (02-22-2012)
  #5
Old 02-21-2012, 10:08 PM
studiot's Avatar
studiot studiot is offline
E-book Developer
Default
You will find the information you seek in publications by
The Radio Society of Great Britain (RSGB)
eg
The Radio Data Reference Book by Jessop, p221 references current ratings and other data for SWG copper.
What SWG are you interested in?
__________________
Do I look old?
I don't feel old.
I don't feel anything till noon.
Then it's time for my nap.
  #6
Old 02-22-2012, 03:30 PM
amilton542's Avatar
Default
eg
I'm interested in 24 SWG, but after looking at the conversion table Bertus gave me, the closest approximation in wire diameter was 24 AWG; which was close enough.
For 24 AWG i've got 577mA.
  #7
Old 02-22-2012, 05:24 PM
studiot's Avatar
E-book Developer
Default
My tables have the following data for 24 swg
diameter 0.022 inch
resistance of 1000 yards 63.16 ohms
length in yards per pound 228.3
current rating 0.4561 amps at 1200 amps per sq inch
Turns per linear inch
Enamel 41.6
Single silk 42.1
double silk 40.0
Single cotton 36.7
Double cotton 31.0
Turns per square inch
Enamel 1731
Single silk 1772
double silk 1600
Single cotton 1347
Double cotton 961
Nearest american wire guage 23
__________________
Do I look old?
I don't feel old.
  #8
Old 02-22-2012, 09:35 PM
amilton542's Avatar
Default
Thanks studiot.
I don't suppose you know a good method on how get your hands on the other end of the conductor that is embedded inside a bobbin of coil like this http://www.maplin.co.uk/enamelled-copper-wire-44
I can do it buy hand and get it nice and tight so it looks exactly how it did before, but to do it by hand to eight bobbins of 24 SWG copper wire will take me days.
I was thinking of a drill set-up, but I think it could prove awkward trying to get the windings tight.
  #9
Old 02-22-2012, 10:43 PM
studiot's Avatar
E-book Developer
Default
Both the RSGB and Babani publications had practical amateur coil winders based on hand drills and sewing machines etc. I have also seen Knitmaster hand cranked wool winders pressed into service.
The main issue is a turns counter. Some electronics mags of yesteryear had designs for this. You can also modify a bikeometer or wheeled pedometer mechanism for this.
__________________
Do I look old?
I don't feel old.
The Following User Says Thank You to studiot For This Useful Post:
Tags
Related Site Pages
Section Title
Worksheet Wire types and sizes
Video Lecture Wire and Cable - Basic Components and Technical Notation
Textbook Copper wire ampacity table : Conductor And Insulator Tables
Textbook Conductor ampacity : Physics Of Conductors And Insulators
Textbook Conductor size : Physics Of Conductors And Insulators
Similar Threads
Thread Thread Starter Forum Replies Last Post
High power led dimming ktnch General Electronics Chat 17 01-20-2011 06:12 PM
Smart current sink for testing shorts? MATTY B The Projects Forum 13 11-24-2010 06:48 AM
Working Of 7805 Linear Regulator IC shankey_1919 General Electronics Chat 4 02-19-2010 11:33 AM
quick check ihaveaquestion Homework Help 23 05-07-2009 09:00 PM
The "real" direction of electric current wbeaty General Electronics Chat 3 07-17-2005 03:23 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
