All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-05-2012, 03:05 PM
THE_RB's Avatar
THE_RB THE_RB is offline
Default Divide by 2 flipflop with 3 NAND gates?
Hi, I need a divide by 2 "flip flop" logic device, and rather than add an entire new flip flop IC to the design I have 3 spare NAND gates.
Does anyone know if it is possible to make a divide by 2 type flip flop using just the 3 NAND gates?
The input is a logic level 0v-5v square wave with a duty of 40-60%, somewhere around 10kHz and I need an output at half the frequency and 50% duty cycle. It doesn't matter if it triggers from the / edge or the \ edge of the input signal, as long as it divides by 2 and gets exactly 50% duty.
I have made S/R flip flops from NAND gates, which just takes 2 gates, so maybe it's possible to add another NAND gate and make it a toggle type (divide by 2) flip flop? I've been working with PICs for so many years that I'm rusty on the fine details of working with discrete logic gates, I think the last time I tried to make something complex out of gates was in the late 70's.
Thank you.
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
  #2
Old 02-05-2012, 03:26 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Any other logic at all? I cut my teeth on Master/Slave FF, it might be possible to do something with diode steering.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
crutschow's Avatar
crutschow crutschow is offline
Default
I believe you would need more gates. Here's a reference discussing the various types of FFs.
__________________
Zapper
Curmudgeon Elektroniker
  #4
Old 02-05-2012, 04:18 PM
praondevou's Avatar
praondevou praondevou is offline
Default
Can any other components be used too? Like capacitor, resistor, diode?
__________________
  #5
Old 02-05-2012, 04:19 PM
Super Moderator
Default
That is what I was asking in post #2.
__________________
General info:
  #6
Old 02-05-2012, 08:55 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
You would need six NAND gates, and one of them would need to have three inputs.
__________________
General info:
  #7
Old 02-05-2012, 10:06 PM
holnis holnis is offline
Member
Default
I think it's possible with using just 3 NAND gates, Take a look to the link given on the post #3, From there on the diagram of the D- flip-flop we can Conclude this equation:
C= Clock
D= Data
Q= Output
Q(t+1) = ((DC)' + (Q + (D'C)' )' )'
After Simplification:
Q(t+1) = ((DCQ)' . ( DC (D + C') )' )'
Q(t+1) = ((DCQ)' . (DC)' )'
So I think it's possible With just 3 NAND, one of them would need to have three inputs.
Maybe I'm wrong!
  #8
Old 02-06-2012, 06:21 AM
crutschow's Avatar
Default
To divide by two you need an edge-triggered FF and that requires more than three gates.
__________________
Zapper
  #9
Old 02-06-2012, 12:05 PM
SgtWookie's Avatar
Expert Member
Default
Quote:
Originally Posted by holnis View Post
I think it's possible with using just 3 NAND gates, Take a look to the link given on the post #3, From there on the diagram of the D- flip-flop <snip>
Unfortunately, that D-type FF schematic in that link isn't correct. If Q\ is connected to D, and then CP goes high, the circuit will oscillate at high frequency.
As crutschow mentioned, it needs to be edge-triggered, and that takes more gates.
__________________
General info:
  #10
Old 02-06-2012, 03:50 PM
THE_RB's Avatar
Default
Thank you Crutschow for the great link on flip-flops! Ok so I don't feel so bad now that my couple of quick attempts to make a /2 circuit out of 3 NAND gates didn't work.
The circuit has three 2-input NAND gates spare. They are schmidt trigger input type. The other NAND gate is used as an oscillator, and the desired result from the one chip is to get a rough frequency output but at exactly 50% duty (hence the /2 idea).
I don't want to add other chips but maybe it can be done with a couple of extra discretes? Since the oscillator is a fixed freq (say +/-10% freq accuracy) it might be possible to use an RC timed circuit on the output to cause the /2 toggling?
I also considered using a dual flipflop IC with one FF being the oscillator and the other FF as the /2, but I could not find an easy source for a FF with a schmidt trigger input as the oscillator needs to be fairly reliable so a schmidt input is desired.
If it starts getting too parts-heavy I can always use a $1 PIC, but I prefer if possible to use a 15 cent quad NAND gate. Any suggestions appreciated.
__________________
Tags
Related Site Pages
Section Title
Worksheet Counters
Worksheet Flip-flop circuits
Video Lecture Sequential Logic - Digital
Textbook Ring counters : Shift Registers
Textbook Serial-in/serial-out shift register : Shift Registers
Textbook Finite State Machines : Sequential Circuits Counters
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook Asynchronous flip-flop inputs : Multivibrators
Textbook The J-K flip-flop : Multivibrators
Textbook NAND gate S-R flip-flop : Digital Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Use a 4060 to divide by 256? frankpc The Projects Forum 18 09-12-2011 07:15 PM
ic number for a t flipflop and an external clock anamta Homework Help 3 12-30-2010 01:52 PM
Can 555 be converted to a jk flipflop. KMK The Projects Forum 13 12-24-2010 10:43 PM
subtract from and divide a 0-5v signal elRey General Electronics Chat 3 09-05-2009 03:09 AM
How can I divide the frequency peterlan General Electronics Chat 14 09-14-2008 03:46 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
