All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-19-2012, 06:55 AM
bluegreen bluegreen is offline
Junior Member
Default guitar Amplifier
I am planning to design a low end solid state guitar amplifier with distortion from scratch. Could someone guide me and help me with suggestions as to how to go about doing this and what books and references I need to use to complete this.
  #2
Old 01-19-2012, 10:16 PM
bountyhunter bountyhunter is offline
Default
You can add the distortion circuits, there are a number of them around. I built one back in the 60's called a "fuzz box" which was a two transistor distortion booster.
As far as the amplifier, there are tons of circuits around but I don't know what input level/impedance and output power you need.
The Following User Says Thank You to bountyhunter For This Useful Post:
bluegreen (01-20-2012)
  #3
Old 01-20-2012, 01:40 AM
PaulEE's Avatar
PaulEE PaulEE is offline
Default
Quote:
Originally Posted by bluegreen View Post
I'm in the process of doing this exact same thing, only I have a tube pre-amp.
The distortion isn't a big deal...were you thinking solid state with discrete components, or solid state with a chip amp?
__________________
Best,
PaulEE
youtube.com/pianoman0488
The Following User Says Thank You to PaulEE For This Useful Post:
  #4
Old 01-20-2012, 01:50 AM
MrChips's Avatar
MrChips MrChips is online now
Super Moderator
Default
You need to say how many watts of power you need? What diameter, power and how many ohms is the speaker? How many inputs? Bass/mid/treble controls? Foot switch for distortion? How about foot switch for power boost? What type of music you play? Acoustic guitar with pickup or solid body electric? Classical, folk, R&B, jazz, rock, heavy metal?
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
  #5
Old 01-20-2012, 03:20 AM
Junior Member
Default
Thanks for the input guys. I have not yet decided on the specifics. I would prefer simple discrete components and basic ICs over chips which have an all in one functionality. Maybe a tube preamp and o/p power of 3-5W.
  #6
Old 01-20-2012, 03:23 AM
Junior Member
Default
acoustic with pickup and an electric Ibanez
  #7
Old 01-20-2012, 03:29 AM
PaulEE's Avatar
Default
A great reference is a book called "microelectronic circuits" by sedra and smith.
In this book and in many other places, you might run into an op-amp + push-pull transistor amplifier circuit. These are great little circuits to start with, especially in the few watt range. Though it is a bit much, the OPA2227 is a great op-amp for a few reasons; low noise, high open loop gain, low distortion, and moderate output current.
The output current capability allows the op-amp to be connected straight to the push-pull stage. In unity-gain configuration, with the "-" lead of the op-amp connected to the output of the push-pull, the op-amp biases the transistors as necessary and provides an overall low-distortion circuit.
I just got done playing with my circuit: the OPA2227 has two separate amplifiers; one I used as non-inverting voltage gain (gain of about 100) and the output was fed into a unity-gain follower like the circuit I described above. The unity-gain follower uses some hefty MJL/MJE transistors (that will eventually be cranking much more than my little ten watts). It wasn't shaking the house apart, but it was plenty loud in my bedroom with my telecaster hooked up to it...
__________________
Best,
PaulEE
  #8
Old 01-20-2012, 03:31 AM
MrChips's Avatar
Super Moderator
Default
I don't think 3-5W would be of much use. I would up it to 10-15W.
__________________
  #9
Old 01-20-2012, 02:30 PM
PaulEE's Avatar
Default
Quote:
I think 3-5 watts is fine for someone who is looking to get acquainted, don't you?
__________________
Best,
PaulEE
  #10
Old 01-21-2012, 12:56 AM
THE_RB's Avatar
THE_RB THE_RB is offline
Default
Yep. Many small practice amps used a 1W LM386, which is loud enough to be annoying in a bedroom, and louder than a person singing and louder than an acoustic guitar.
But if you play alongside a real drummer you need 50W+ (and you need somewhere to practice!!).
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
Tags
Related Site Pages
Section Title
Video Lecture Op Amps Characteristics (Part 4) - Common vs. Differential - Op Amps and Op Amp Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help regarding audio amplifier.. sarang2502 General Electronics Chat 16 04-27-2010 10:16 PM
LM356 op-amp based guitar amplifier specialedster The Projects Forum 5 12-23-2009 12:55 AM
How to do a -16db attenuator for a guitar amplifier Oldwolf General Electronics Chat 7 12-26-2008 09:49 PM
Making a guitar amplifier focusdeepwar General Electronics Chat 3 08-26-2005 10:07 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
