All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-10-2007, 01:11 PM
amaynew amaynew is offline
Junior Member
Default Need help for Home made audio amplifier
Guys, I suck at designing circuits and I was wondering if you could help me create a schematic for a 200W audio amplifier, and take note it must not use Op-amps.
And if you have Circuit design tips, I would gladly want to read them. Thanks. I wanted to learn how.
  #2
Old 07-10-2007, 01:25 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
Well, I could give you tips, but the users of this forum usualy don't create circuits on demand. Please, show us what you have done so far. Post your circuit diagram so we can help.
__________________
I love the smell of toasted transistors in the morning.
  #3
Old 07-10-2007, 03:48 PM
lightingman's Avatar
lightingman lightingman is offline
Default
There are many designes for high power amps out there....First you must ask yourself what it will be used for, (general PA, high quality audio and so on)....Next,,, what type of amp.. (class A, class B) and so on.....What devices do you wish to use (bipolar transistors, MOSSFET''s or valves)...The design of audio power amps is a complicated proccess....Look at some other designes to get some ideas, but I don't think you could come up with anything ground breaking....Good luck...Daniel.
  #4
Old 07-10-2007, 03:56 PM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
visit ... http://www.littlefishbicycles.com/poweramp/ for an idea.
__________________
Joe
Navy Electricity and Electronics Training Series (NEETS) - pdf files - http://www.fcctests.com/neets/neets.htm
  #5
Old 07-10-2007, 06:28 PM
Default
If you are new to electronics, you can use a power amplifier IC for your amplifier. ST electronics has a wide selection (TDA2003, TDA2006, TDA2030, etc.). Venturing to discrete components requires a lot of knowledge.
Also, I would advice the use of class A or class AB if you wan't fidelity. Class B is more efficient that the previous classes, but it has higher distortion. Class A theoretically has no distortion, but is the least efficient. Class AB is the best of both classes (very small distortion and highter efficiency than class A - push-pull configuration). Class C is not an option here.
__________________
  #6
Old 07-10-2007, 11:28 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
http://www.dogstar.dantimax.dk/tubestuf/dzindex.htm
...not a "beginner level" project, by any means, but it is 200+ Watts with no op-amps.
By the way, why the "no op-amps" requirement?
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #7
Old 07-11-2007, 06:58 AM
mrmeval mrmeval is offline
Default
The 'no op amps' sounds like some neolithic techur requirement.
Tags
Related Site Pages
Section Title
Worksheet Design Project: audio media-based signal generator
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Negative feedback opamp circuits
Worksheet Design Project: Audio power amplifier
Worksheet Class C BJT amplifiers
Worksheet Class B BJT amplifiers
Textbook Tubes versus Semiconductors : Electron Tubes
Textbook Class B audio amplifier : Analog Integrated Circuits
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
AV400v2 - Another 400W Hi-Fi audio amplifier with remarkable sound donpetru The Flea Market 0 07-14-2014 05:19 PM
Class A amplifier design help...car audio chunkmartinez General Electronics Chat 20 10-23-2013 11:13 AM
Help needed with input jack and Audio amplifier hunterage2000 The Projects Forum 1 05-22-2013 04:56 PM
Transresistance Amplifier tquiva Homework Help 0 02-12-2012 06:36 AM
audio input switching biggestbrad27 General Electronics Chat 2 08-15-2009 08:24 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
