show the put put wave form for a serial in serial out right shift register for specific dara input and clock signal . required to shift 10 bits out of shift register. assume that register initially contains all 1s.and please draw the timing diagram.
sir ,
I post a problem to you about the digital logic and design under the title of shiftregister please immediately feed back because i have have only 12 hours left to solve this problem which i cannot understand , please in this regard help me quickly
A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
You gave absolutely no information about your problem. I suspect you are not going to get what you need. The more information you give (schematics, setup, etc) the more likely someone will step in and try to help.
Look at the datasheet for the shift register, every time the clock changes, whatever is on the data line is shifted in, and the rightmost bit is shifted out (to next shift register if connected, or discarded otherwise).
The datasheet has a timing diagram.
What part are you having problems with? It's usually best to not wait until the last minute to do homework.
