All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-04-2012, 10:55 AM
kwas_91 kwas_91 is offline
Default Emitter Follower with bootstrap
I have problem with input resistance of emitter follower.
But first quick check:
If I'm correct, equation for input resistance will be:
R_{in} = R_B || R_{in'}
where:
R_B = R_2 || R_3
R_{in'} \approx h_{ie} + (h_{fe} + 1)R_5
Ok, that was quite easy. But the real problem I have with this:
Question is the same - what is equation for input resistance?
First problem is with two transistors. I'm not sure about this part of equation, but it's the best of what I've think of:
R_{in'} \approx h_{ie1} + (h_{fe1} + 1)(h_{ie2} + (h_{fe2} + 1)R_5
But I don't know how to write the rest of the equation.
  #2
Old 01-04-2012, 02:54 PM
Jony130 Jony130 is online now
Default
Well I think that Rin will be equal to:
R_{in} \approx \frac{R4}{1 - Av}||RinT
RinT ≈ hfe*hfe*R5
Av - Voltage gain
  #3
Old 01-05-2012, 05:09 PM
Default
Yes, it's correct! There is only one last think I don't understand with bootstrap and Miller effect.
From what I've seen, this circuits input resistance is much more reliant on input signal frequency. I mean increasing frequency decrease input resistance much faster. Why?
  #4
Old 01-05-2012, 06:52 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
One thing that sticks out to change the behavior on higher frequencies is C2. With higher frequencies, C2 provides a transistor bypass path to 220Ω to ground. Why is it there?
What else may affect the input impedance?
Tags
Related Site Pages
Section Title
Worksheet Active filters
Worksheet AC negative feedback opamp circuits
Worksheet Negative feedback opamp circuits
Worksheet Oscillator circuits
Worksheet Class A BJT amplifiers
Textbook More on the ``skin effect'' : Reactance And Impedance -- Inductive
Textbook BJT quirks : Bipolar Junction Transistors
Textbook Feedback : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
emitter follower query harry99932 General Electronics Chat 4 05-19-2011 01:24 AM
mystery of emitter follower output impedance acelectr General Electronics Chat 20 03-30-2011 11:24 PM
AoE mathematical explanation of emitter follower impedance BrianH Math 2 09-26-2010 09:37 AM
Emitter Follower Clipping jonnylazer Homework Help 1 01-12-2010 06:54 PM
Impedance matching with emitter follower Eduard Munteanu General Electronics Chat 1 09-10-2007 12:12 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
