All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-02-2012, 09:32 PM
epsilonjon's Avatar
epsilonjon epsilonjon is offline
Member
Default Capacitive coupling
Hi. The book i'm reading is just going over the basics of a BJT amplifier using the circuit below. It says the ac voltage is superimposed onto the dc bias voltage by capacitive coupling, but it doesn't seem correct to me.
I've read some bits on the internet about what capacitive coupling is and I think I understand it. I also read the AAC info on biasing techniques http://www.allaboutcircuits.com/vol_3/chpt_4/9.html which has a similar circuit to the one below, but which makes sense to me.
For this circuit below, I don't get how can be the ac voltage shown. Using superposition is just isn't it? Also, I don't really get the purpose of capacitive coupling here. Why not just put the ac and dc sources in series with one another and , and leave out the capacitor altogether?
Could someone explain it to me please?
Thanks!
  #2
Old 01-02-2012, 09:49 PM
ceidas ceidas is offline
Member
Default
The first thing we do when we work with transistors is biasing them in the linear region. This is what VBB do. And if we hadnt placed the capacitor the dc current from VBB would go in the Vs. Thats a waste we dont want.
When we are sure that the transistor is correctly biased in the linear region, then we do what we call small signal analysis by making the AC equivalent circuit. Thats the dc circuit but with the dc voltages short circuited and the transistor replaced with the forward active model.
  #3
Old 01-02-2012, 10:01 PM
Adjuster's Avatar
Adjuster Adjuster is offline
Default
Thanks!
This is a confusing circuit, and as shown literally would not work.
Effectively, RB should be in series with VBB, so that it is possible for Vs to affect the base voltage.
If this circuit is on a forum page you might think of sending some feedback about it.
  #4
Old 01-02-2012, 10:14 PM
Member
Default
True, thats why we implement this kind of VBB with two resistors, one connected in CB and an other in BE.
  #5
Old 01-02-2012, 10:15 PM
Adjuster's Avatar
Default
There are a number of reasons for using capacitive coupling. Amongst these are the facts that it may be undesirable to amplify a possibly variable DC voltage, and that it often is not convenient or even possible to put things in series.
A signal source may have a connection to ground, or to some other potential which cannot be removed - for example the signal may come from the collector of another transistor. The DC voltage at the signal source may also not be very stable.
If only AC signals are of interest, as in the case of an audio amplifier, it may be sensible to "divorce" the AC content from the unwanted DC, and replace the latter with a stable bias voltage.
Whether or not the signal source has any DC level on it to start with, the coupling capacitor also prevents the bias from being applied to the signal source, which in some cases would be adversely affected by it.
  #6
Old 01-02-2012, 10:16 PM
joeyd999 joeyd999 is offline
Default
Quote:
But the model is still wrong...regardless.
  #7
Old 01-02-2012, 10:20 PM
Adjuster's Avatar
Default
Quote:
Quite true.
@ Epsilonjon: Wherever that schematic came from, on this forum or elsewhere, some feedback might be in order. What was the source?
  #8
Old 01-03-2012, 09:58 AM
epsilonjon's Avatar
Member
Default
Thanks for all the replies to confirm what I thought about the circuit and explain a bit more about why capacitve coupling is used.
I could forgive the circuit a bit more if it came from a forum or some other free source, but it actually comes from the (rather expensive) book Electronic Devices by Thomas L. Floyd. This circuit comes from the 9th edition of the book, but interestingly I managed to download the seventh edition and in that edition they had the circuit as this:
  #9
Old 01-03-2012, 10:17 AM
Adjuster's Avatar
Default
I think I can see what may have happened. This form of equivalent circuit does not include the coupling capacitor, and shows the bias voltage as actually in series with the signal, which is uncommon in practice.
Perhaps it was suggested that the circuit was changed into a more realistic form, but a mistake was made when this was done. Maybe they will fix it in a future edition?
  #10
Old 01-03-2012, 07:52 PM
epsilonjon's Avatar
Member
Default
Yeah you're probably right. I'd have thought after 9 editions at 50 a pop they might have got it sorted by now, but nevermind. At least it prompts the reader to think about it for themself a bit?
Thanks for your help
Tags
Related Site Pages
Section Title
Video Lecture Capacitors (Part 2) - Current Flow in a Capacitive Circuit - Inductors,Capacitors,Transformers
Worksheet Multi-stage transistor amplifiers
Worksheet Class A BJT amplifiers
Worksheet Basic AC-DC power supplies
Worksheet Performance-based assessments for AC circuit competencies
Worksheet Passive filter circuits
Worksheet Capacitive reactance
Textbook AC bridge circuits : Ac Metering Circuits
Textbook Low-pass filters : Filters
Textbook Input and output coupling : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
coupling capacitor in lna? lna.fyp Radio and Communications 1 09-22-2011 03:02 AM
Capacitive touch pad R!f@@ General Electronics Chat 7 12-26-2010 06:25 PM
Capacitive coupling due to parasitic capacitance. alphacat General Electronics Chat 4 11-15-2009 05:00 PM
Matlab Code for the Extraction of Coupling matrix from S-parameters(.s2p) faisaldj Programmer's Corner 3 06-30-2009 12:29 PM
Why coupling clamp dBuV to dBpW conversion factor is -17 Basket_Case Physics 0 01-15-2009 09:57 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
