All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-30-2011, 06:58 AM
jaygatsby jaygatsby is offline
Banned
Default Prefered adhesive for circuit boards
I want to glue a couple DB25 connectors to a board. Would you recommend hot glue, super glue, or something else?
Thank you
  #2
Old 12-30-2011, 07:16 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Are your connectors plastic or metal?
If they are metal, you could use some J-B Weld. That's about as permanent an adhesive that is on the consumer market.
Circuit boards are fiberglass, which means they are glass and epoxy.
Plastic usually won't stick with epoxies very well.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 12-30-2011, 05:08 PM
Banned
Default
The db25 socket is plastic, the board is the normal fiberglass circuit board. I want it to stay fairly well because I'll be connecting cables.
  #4
Old 12-30-2011, 05:49 PM
SgtWookie's Avatar
Expert Member
Default
Doesn't the socket have mounting holes? DB25 connectors usually have mounting holes at either end. You can use standoffs to attach the connector at either end. If it's a circuit board that you made, drill a couple of matching holes for mounting it. If it's not your design, drilling holes in it may cause big problems, particularly if there are hidden layers.
In that case, the safest way to secure it would be to use hot glue.
__________________
General info:
  #5
Old 12-30-2011, 06:11 PM
Banned
Default
Thanks -- I'll try hot glue. I can't mount the connectors they way they were intended to be mounted because the pins do not line up with the pin holes on my perfboard, and so I've wired them upside down.
  #6
Old 12-30-2011, 06:40 PM
SgtWookie's Avatar
Expert Member
Default
When you are using perfboard, you have to get creative. Use a drill to make the holes you need.
__________________
General info:
  #7
Old 12-30-2011, 07:46 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
Second on the drill.
Hot glue holds stuff down for vibration and minor tugs once in a while.
A DB connector is typically yanked hard in various directions when trying to get the right side up and fully connected when not in plain view.
  #8
Old 12-30-2011, 08:19 PM
Lundwall_Paul Lundwall_Paul is offline
Default
What ever glue you decide on make sure that it is non-conductive.
  #9
Old 12-30-2011, 08:24 PM
john_doe01 john_doe01 is offline
Default
Bluetack!
  #10
Old 12-30-2011, 09:18 PM
Banned
Default
I bought some of the 'extra strong' glue and a glue gun. I'm using a ribbon cable connected to DB25s to connect to the connectors I'm gluing down, and it's internal use so no people tugging on it.... hopefully it will work out.
Tags
Related Site Pages
Section Title
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook "Ladder" diagrams : Ladder Logic
Similar Threads
Thread Thread Starter Forum Replies Last Post
STMicro Dev Boards Potato Pudding Embedded Systems and Microcontrollers 2 06-23-2011 07:23 AM
PCI 24CH Data Acquisition Boards for PC based automation BMorse Off-Topic 0 03-06-2010 06:29 PM
Cash For Gold and old Circuit Boards - Need Advice. maxpower097 General Electronics Chat 7 01-06-2010 09:09 PM
Heatsink Adhesive Dave Computing and Networks 8 05-28-2007 11:17 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
