question about floating gates and tunneling
magnet18
Joined Dec 22, 2010
1,227
OK, as I understand it from 5 minuets on wikipedia, a solid state hard drive has the general layout of a mosfet, but with a secondary floating gate between the primary gate and the depletion region. When voltage is applied to the gate, it pulls electrons towards it and the floating gate. Fet turns on and the electrons begin flowing through the absence of holes along the oxide. Then, since the electrons are pulled towards the primary gate, some of them... tunnel through the oxide, losing energy and becoming trapped there, keeping a "permanent" voltage on the floating gate.
I have two questions.
1, if the electrons are on the floating gate, wouldn't the voltage be negative, keeping the FET off?.
2, WTF if tunneling?
I know it's Heisenberg uncertainty principle and stuff, and that some electrons can get to the other side by... trading energy for motion or something?
What do they actually do?
slide through the lattice structure?
teleport?
:confused:
(feel free to move this to physics if you want)
JDT
Joined Feb 12, 2009
657
Well I'm not an expert on this but you are correct that a flash memory cell uses a mosfet with a floating gate as well as a control gate. Charge is put on the floating gate by quantum tunneling. This does not switch the mosfet on or off but changes the threshold voltage of the transistor. Then when a certain voltage is applied to the gates of an array of these transistors, some will switch on and some will not.
http://en.wikipedia.org/wiki/Flash_memory#Floating-gate_transistor
http://en.wikipedia.org/wiki/Hot_carrier_injection
magnet18
Joined Dec 22, 2010
1,227
OK, thanks, I think that makes sense.
On power up, a certian voltage is applied to the FET's to see which ones have charge in the floating gate, and should be switched fully on?
34,464
2. Tunneling is a quantum effect where there is a certain probability of an electron going through a thin insulator or barrier that classical physics says it cannot. Here's a further explanation.
magnet18
Joined Dec 22, 2010
1,227
WIKIPEDIA said:
the probability of a given particle's existence on the opposite side of an intervening barrier is non-zero, and such particles will appear—with no indication of physically transiting the barrier—on the 'other' (a semantically difficult word in this instance) side with a frequency proportional to this probability.
so... it just appears?
no jumps, no crashes, nothing... it just ceases to exist on one side and then exists on the other?
34,464
Yes. The quantum world is a place of weird and strange happenings, many of which don't seem to make much sense based upon the macro world we know. For example light photons directed through two small parallel slits cut in a plate will generate an interference pattern on the opposite side of the plates on photographic film. This is attributed to the wave nature of the light. But you will get the same interference pattern if you just put one photon at a time through one of the slits. But if you cover one slit, the interference pattern goes away!.:rolleyes:
magnet18
Joined Dec 22, 2010
1,227
yea, double slit experiment...
I don't get that either
the light interferes with itself... mind blown
thatoneguy
Joined Feb 19, 2009
6,359
It goes back to the quote by some scientist:
"There's only maybe 3 people that fully understand quantum mechanics, myself, and I forgot the other two"
Now there is string theory to counterpoint quantum mechanics and all sorts of stuff.
Knowing fully the interactions and details of both will pretty much guarantee you won't marry a supermodel.
magnet18
Joined Dec 22, 2010
1,227
psh, gave up on that a long time ago... decided I could settle for a rich lawyer or something ;)
