tDCS Schematic Confusing
Status
Not open for further replies.
NathanielZhu
Joined Dec 5, 2011
50
So I have no experience with circuits at all.
I think I get the gist of how the thing is put together, but the one thing that confused me was the little box on the left side titled "Current Regulator".
I'm guessing this current regulator gives a more detailed description of the LM317 current regulator, but I don't see how it relates to the actual circuit work.
I've seen pictures of LM317 and doesn't look anything like the box on the left side titled "Current regulator".
So, once I buy LM317 from Radio Shack, what do I do with it to match up with the box on the left side?
Overall, this device is supposed to generate 1mA of electricity through the anode/cathode. Don't tell me how unsafe it is because I assure you, it has been well tested. Lab-grade equipment is sold for 3000 dollars. Someone had already developed a personal version which is this schema and released it.
SLK001
Joined Nov 29, 2011
1,549
Look at your "head" as the load. For 1mA of current, a resistance of 1250 ohms is needed. Your schematic accomplishes this with a series 1200 and a 51 ohm resistor pair.
Tell me, what is this for? What does it do? And why would you do it?
NathanielZhu
Joined Dec 5, 2011
50
Well, this device stimulates neurons with a very low amount of electricity.
I found the schematic on http://brmlab.cz/project/brain_hacking/tdcs
All the research I found on this showed positive results with side effects being minor. The air force according to one research found that it took students 1/2 the time to acquire the motor skills in their training program with tDCS compared to the students without it.
Well, my question mainly was mainly about the stuff in the light blue box. It just doesn't seem relevant to the rest of the schematic.
Here, I circled it.
SgtWookie
Joined Jul 17, 2007
22,230
Whoever came up with that constant current regulator schematic didn't bother to read the datasheet which says that the LM317 needs a minimum of 10mA current output in order to provide guaranteed current and voltage regulation. They are attempting to regulate it at 1/10th of the minimum current, and the output current will not be regulated worth a darn. I don't know offhand what the current will be, but it'll be more than 1mA.
Even the LM317L, the 100mA TO-92 package version, requires a minimum of 5mA to provide guaranteed regulation.
NathanielZhu
Joined Dec 5, 2011
50
oh. Do you think it'll be more than 2mA? The 1mA ought to be the current that reaches the brain but the skull provides a lot of resistence.
Can you help me with my previous post? I'm having trouble understanding what the box on the left corner is for (I circled it in my previous post)
SgtWookie
Joined Jul 17, 2007
22,230
I frankly don't know how much current you will get. The resistance between OUT and ADJ is way out of specifications. I've never tried going that far beyond the specifications.
The box on the left is an excerpt from the datasheet.
While R1 = ~1.25/Ireq; they omitted that 10mA <= Ireq <= 1.5A, so 0.8333 Ohms <= R1 <= 125 Ohms. They are using 1251 Ohms, or more than 10 times the maximum allowed.
bertus
Joined Apr 5, 2008
23,014
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
Bertus
Status
