All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-21-2007, 08:10 AM
Littlehajime Littlehajime is offline
Default Firing angle Delay
i'm new into power electronic
and i'm assign to do some research about
FIRING ANGLE DELAY
anyone able to explain to me what is it ? and how does it work ?
and where i can find more info about it ?
  #2
Old 06-21-2007, 12:11 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
If you consider a sine wave, that can be represented by the function:
Code:
V(t) = A*sin(wt)
where A is the amplitude, w is the radian frequency, and t is time.
Select All
Each value of t when multiplied by w represents an angle. To change the amount of power present in a sine wave you can change the value of A which may be undesireable or you can set the value of A to zero for some part of the cycle. The resulting waveform looks like a step function at the firing angle, and like a sine wave until the next zero crossing.
The Root Mean Square(RMS) value of the resulting waveform will be less than the RMS value of the full waveform.
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 06-21-2007, 05:25 PM
Default
woah ~~~
dont really get what u mean =)
i was told to design a circuit tat able to adjust firing angle
i don't really understand what is a FIRING ANGLE ?
  #4
Old 06-21-2007, 06:00 PM
Papabravo's Avatar
Default
I told you what a firing angle was. It is the angle on the sine wave where a switch turns on. The switch turning on, like any switch, allows current to flow. What was wrong with the explanation? If you didn't understand it, then I think you will have great difficulty in designing a circuit.
__________________
  #5
Old 06-22-2007, 05:05 PM
recca02's Avatar
recca02 recca02 is offline
Default
i will try though i have a little understanding of the topic.
firing angle is the angle of the signal/supply at which u switch your scr to act as normal diode. the signal might be a sinusoidal one. and as value of sine changes with angle . we can adjust the power delivered by the wave by turning the scr on at different angle of the sine wave. the portion for which it remains off no power will be delivered.
  #6
Old 06-22-2007, 05:34 PM
Papabravo's Avatar
Default
I guess the OP will have to weigh in on the clarity of that explanation in contrast to the others.
__________________
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Flip-flop circuits
Worksheet Thyristor application circuits
Textbook Credits : Contributor List
Worksheet Design Project: DC motor
Textbook Series resistor-capacitor circuits : Reactance And Impedance -- Capacitive
Video Lecture Working with Phase Angles (cont) - Alternating Current
Video Lecture Working with Phase Angles - Alternating Current
Textbook Polar and rectangular notation : Complex Numbers
Textbook Time-delay relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
SCR firing circuit? newbie needs help~~~ adamsadam The Projects Forum 13 05-11-2007 03:26 AM
Triganometry(cosine of an angle) chunkmartinez Math 3 01-22-2007 09:32 AM
Need to design a simple 12v delay kwhitelaw The Projects Forum 1 11-13-2006 04:37 AM
12v current timer, delay box chaz6966 General Electronics Chat 8 10-02-2006 02:15 AM
DC Power Delay - 5 seconds ON and 190 seconds OFF | HELP we87 General Electronics Chat 9 09-28-2006 06:23 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
