Find the datasheet for the 7812 integrated circuit. It's a 3-pin component that will regulate the voltage of your supply to 12v. Very simple and handy. That datasheet will show several application examples that will help you, in addition to what's been suggested already.yet no body has define clearly and exact plz guide and explain with suitable example
I'd start with a transformer rated for about 14VAC - 16VAC on the secondary winding with a rating of 1A RMS or higher. Bridge rectifier rated at least 60V and 2A (higher is better). Filter cap should be 25V rated at about 5,000 - 10,000 uF.
It is not a simple derivation. There are rules of thumb used:sir my purpose is not only build this circuit but also i want to learn concept
can you explain me with example thanks
Experience. Hard to summarize.sir why you choose 14vac -16ac , bridge rectifier- 60v, capacitor-25v
give specific reason
by Aaron Carman
by Jake Hertz
by Aaron Carman
