Hi People,
I am trying to calculate the RPM of a bicycle and I have written the code in mikroc for calculating the time it takes for falling and the rising edge of a reed switch which is connected to the rear wheel.
Therefore 1 pulse = 1 revolution in this case, so I have attached the code below and for testing purpose I have created a simulation phase which will display the RPM on a LCD but the LCD does not display it for some reason!
I used the CCP2CON register RC1 to capture the falling and the rising edge.
All I see is '1' displayed on the LCD with the welcome text.
This is the code:
//#include <stdio.h>
char *text = "Cadence";
char buffer[20];
//char *text1 = "RPM";
float Rpm;
unsigned int Rot_time = 0;
unsigned short Pulse_HSL; // holding falling edge time for start of timing sequence
unsigned int Pulse_HSH;
unsigned short Pulse_EL; // rising edge for end time sequence
unsigned int Pulse_EH;
//unsigned float Rot_PH = 0;
//unsigned float Rot_PL = 0;
void main()
Soft_Uart_Init(PORTC,7,6,57600,0);
delay_ms(500);
PORTB = 0;
TRISB = 0;
TRISD = 0; //Set all PORTD for output
PORTD = 0;
TRISC = 0x02; //RC1 as input for CCP2
Lcd_Init(&PORTB);
Lcd_Cmd(Lcd_clear);
Lcd_Out(1 ,1 ,text);
INTCON = 0; //Disable all Interrupts for initialization of other registers
T3CON = 0; //0000 0000 was $C0 Sets Timer1 as source clock for CCP1 and CCP2 leaves timer3 off
CCP2CON = 0x04; // set for every faling edge, 05 every rising edge capture
//CCP2CON = 0x06; //set for 4th rising edge, $07 Initially Set CCP2 for 16th Rising Edge Capture
T1CON = 0x01; //set for 8 bit time read, prescaler of 1 and turn timer 1 on
//T1CON = 0x81; // set for 16bit read, prescaler 1 and timer1on
TMR1L = 0x00; //zero timer registers
TMR1H = 0x00;
INTCON = 0xC0; //Enable Interrupts
while(1)
//Lcd_cmd(Lcd_clear);
//delay_ms(1000);
if(PIR2.CCP2IF == 0 && CCP2CON == 0x04) // if flag is set and pulse is trigerred
Rot_time = (Pulse_EH<<8|Pulse_EL) - (Pulse_HSH<<8|Pulse_HSL);
Rpm = 240000000/Rot_time;//combining both hi and low byte of rotation period
wordtostr(Rpm,buffer);
//sprintf(buffer, "%12s", Rpm); // this is taking F* lot of ROM locations
Lcd_Out(2,1,buffer); // Print text on LCD
Soft_Uart_write(buffer);
void interrupt()
//INTCON.GIE = 0; // clearing GIE to prevent any other interrupts while handling this one
if(PIR2.CCP2IF == 1)
switch(CCP2CON)
case 0x04: // start time of the sequence i.e. falling edge and gets start time
Pulse_HSL = CCPR2L; // capture pulse high start time
Pulse_HSH = CCPR2H; // get captured time high byte
CCP2CON = 0x05;
PIR2.CCP2IF = 0; // reset the flag
break;
case 0x05: // end time sequence so timing sequence complete, calculate time intervals
Pulse_EL = CCPR2L; // get time of the rising edge
Pulse_EH = CCPR2H;
//Rot_PL = Pulse_EL - Pulse_HSL; // rotation time = Pulse time HI + pulse time LOW
//if(STATUS == 0){ Pulse_EH = Pulse_EH - 1; }
//Rot_PH = Pulse_EH - Pulse_HSH;
CCP2CON = 0x04; // set start next timing sequence for falling edge.
PIR2.CCP2IF = 0;
break;
default: rpm = 0;
} // switch
} // if
} // interrupt
The text i.e in red is the code where I am printing the RPM on a LCD.
I have also attached the schematic where you can test the code and see the LCD output for your reference.
Please help me resolve this issue, I am using Mikroc v8.2 and PIC18f452 with 16mhz. I used Proteus professional simulation software for generating the schematic.
If you have any other question please feel free to reply me!
Cheers
vivek
This is the code:
char buffer[20];
float Rpm;
void main()
delay_ms(500);
PORTB = 0;
TRISB = 0;
PORTD = 0;
Lcd_Init(&PORTB);
Lcd_Cmd(Lcd_clear);
TMR1H = 0x00;
while(1)
//delay_ms(1000);
void interrupt()
switch(CCP2CON)
CCP2CON = 0x05;
break;
Pulse_EH = CCPR2H;
PIR2.CCP2IF = 0;
break;
default: rpm = 0;
} // switch
} // if
} // interrupt
Cheers
vivek
