All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-16-2007, 06:50 PM
horsebox horsebox is offline
Junior Member
Default Building a DC to DC step up transformer
I was wondering if I could build a DC to DC step up transformer by making two solenoids and hooking up a potentiometer to the first one to create a changing current which should make a fluctuating magnetic field and hopefully induce enough voltage in the second solenoid to light up a small LED.
Is it possible?
  #2
Old 06-16-2007, 08:19 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
If you create a changing current, it can't really be called "DC" anymore.
Beyond that, I don't understand the description. Can you post a diagram?
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #3
Old 06-16-2007, 09:25 PM
Junior Member
Default
I cant draw for beans but there it is
  #4
Old 06-17-2007, 04:49 AM
Super Moderator
Default
You'll have to turn your potentiometer from minimum to maximum and back faster than the eye can follow. The solenoids would need to be wound on the same core.
You might have better luck with a more conventional DC to DC converter: http://www.powerdesigners.com/InfoWe...converter.shtm
__________________
- Michael Faraday
  #5
Old 06-22-2007, 08:29 AM
Junior Member
Default
This is the kind of thing i was talking about only having an LED instead of a compass and a potentiometer instead of a switch.
I think I finally understand inductance. Would I be right in assuming inductors only really work in AC circuits since it requires a changing magnetic flux to induce current?
  #6
Old 06-22-2007, 11:21 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
Being that the case, you will only detect current flowing through the secondary in the instant you switch the primary on or off, since only alternating magnetic fields can induce current, and that is why only in those instants you can induce current (because it varies). However, you can use a relay to create an astable "multivibrator" (equivalent to a vibrator in old valve equipment). To do that use the normally on contact of the relay in series with the relay coil/transformer paralel association. This works because once the relay is magnetized, it atracts the switch causing a break in the circuit (is a normally on contact, remember!), thus interrupting the current flowing through the relay coil, demagnetizing it again. The whole process is a cycle of on-off pulses.
__________________
I love the smell of toasted transistors in the morning.
  #7
Old 06-24-2007, 12:29 AM
Joe24 Joe24 is offline
Member
Default
Well the mutual inductance of Transformers can also be useful when there is DC present. For example, a transformer can be used for DC Isolation in application involving cascaded amplifiers. By using a transformer in between two amplifiers, it can be used to keep the DC voltage on the output of the first amplifier stage from affecting the DC bias of the next amplifier.
  #8
Old 06-24-2007, 01:08 AM
recca02's Avatar
recca02 recca02 is offline
Default
change in flux linkage is required for inductance.
and flux linkage is proportional to current.
hence current variation is required.it need not necessarily mean an ac. only change in magnitude of current wud do.
actually the rate of change is important
  #9
Old 06-25-2007, 11:10 AM
Default
Well, you won't need to have AC current. Any DC signal will do. As someone said, coupling transformers were used in amplifiers. It is not uncommon to see one in an old tube amplifier, feeding a speaker.
Actually, you may see vibrators being used in tube radios that used batteries. The vibrator would create a pulsating current to feed a step-up transformer, so we would have HT for the valves.
__________________
Tags
Related Site Pages
Section Title
Worksheet AC motor theory
Worksheet Advanced electromagnetism and electromagnetic induction
Worksheet Step-up, step-down, and isolation transformers
Worksheet Mutual inductance
Worksheet DC generator theory
Textbook Practical considerations : Transformers
Textbook Special transformers and applications : Transformers
Video Lecture Inductors (Part 1) - Inductors,Capacitors,Transformers
Textbook Inductor commutating circuits : Diodes And Rectifiers
Textbook Mutual inductance : Magnetism And Electromagnetism
Similar Threads
Thread Thread Starter Forum Replies Last Post
Worksheets Help Dc dc conversion by using transformer for isolation bjrajendra General Electronics Chat 0 07-08-2014 06:46 AM
Step down DC voltage dk_kush General Electronics Chat 4 08-05-2010 06:57 PM
Building a Transformer jegonz General Electronics Chat 2 02-28-2008 10:38 AM
transformer response to a step input AlexK General Electronics Chat 2 06-04-2007 07:58 PM
Help with 12V DC Step Down resistor values dsmith The Projects Forum 1 04-26-2007 02:17 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
