All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-15-2011, 12:33 AM
jegues's Avatar
jegues jegues is offline
Question Series-Shunt Feedback Amplifier
I think I managed to get part a), but I'm stuck on part b).
I wrote all the equations I could think of in the circuit but I'm still a little stuck as to actually solving the DC emitter currents. Is there an assumption I can make about any of the other currents?
For example,
Can I assume,
I_{c1} \approx I_{1}
Is this acceptable? Or should I be able to solve for everything?
I feel like I need to solve 1 value or make an assumption in order to get things rolling.
Thanks again!
  #2
Old 11-15-2011, 02:09 AM
t_n_k t_n_k is online now
Default
The closed loop gain should be ~100.
  #3
Old 11-15-2011, 02:33 AM
Default
For the currents you can do an incremental approach.
First assume IB1≈0.
Then calculate the current in R1=0.7/1k=0.7mA. Hence current in R2=0.7mA and hence it follows that IE2=1.7mA.
Thus IB2=1.7mA/101=16.8uA.
This makes IC1=100uA-16.8uA=83.2uA. Thus IB1 would be better approximated as 832nA.
You could redo the process now using IB1=832nA rather than IB1=0A. But I doubt things would change that much.
  #4
Old 11-15-2011, 02:58 AM
jegues's Avatar
Default
Quote:
How did you draw this conclusion?
I've been reading in the book how to estimate the closed loop gain when we have a large loop gain but obviously I found the wrong relationship.
My reasoning was as follows,
A\beta \rightarrow \infty
A_{f} = \frac{V_{o}}{V_{s}}= \frac{A}{1+A\beta} \Rightarrow \frac{A}{A\beta} = \frac{1}{\beta}
  #5
Old 11-15-2011, 04:24 AM
Default
Begging your pardon - it should be ~10 rather than ~100. I slipped an order of magnitude in my original "back of the envelope" estimate.
Basically, I'm looking at what happens at the output emitter (E2) as the input varies.
With the input 0V then VB1≈0.7V and hence VE2≈7.7V.
If the input increases from 0V to +10mV then VB1=0.71 V and hence
VE2=7.1+0.71=7.81V.
So the VE2 has changed by (7.81-7.7) 0.11V for a 10mV input change, which equates to a gain of Av=0.11/0.01=11.
If the input is -10mV then VB1=0.69V and VE2=6.9+0.69=7.59V
So for a change from 0V to -10mV the E2 voltage changes by 7.7-7.59=0.11V - again indicating a small signal gain of ~11.
  #6
Old 11-15-2011, 04:29 AM
Default
I can run a simulation to check the result if you don't have access to simulation software.
  #7
Old 11-15-2011, 04:45 AM
Default
Using the idea of feedback you can come up with the gain as follows.
If the open loop gain is Avo then
V_o=A_{vo}\[V_s-\frac{R_1}{(R_1+R_2)}V_o\]
Re-arranging this gives
V_o\[1+A_{vo}\frac{R_1}{(R_1+R_2)}\]=A_{vo}V_s
or
V_o\[\frac{1}{A_{vo}}+\frac{R_1}{(R_1+R_2)}\]=V_s
And if Avo is very large then
V_o\[\frac{R_1}{(R_1+R_2)}\]=V_s
and finally
A_f=\frac{V_o}{V_s}=\frac{(R_1+R_2)}{R_1}
So Af=11 with the given values looks consistent.
Perhaps you have confused the transistor current gain beta values with the feedback beta factor.
i.e.
\beta=\frac{R_1}{(R_1+R_2)}
  #8
Old 11-15-2011, 01:27 PM
Jony130 Jony130 is offline
Default
I was bored today so I decided to find open loop voltage gain.
I use this diagram
And I assume Ic1 = 100uA; Ic2 = 1.6mA
re1 = 26mV/100uA = 260Ω
re2 = 26mV/1.6mA = 16.25Ω
So the voltage gain of the first BJT is equal
 A1 = \frac{Rc}{re} = \frac{( hfe+1)*(re2 + R1+R2)}{re1 + \frac{R1||R2}{Hfe+1} } = 4.13K
And I'm not sure whether this (R1||R2)/(Hfe +1) should be take into account.
Voltage gain for Q2 is equal
 A2 =\frac{Re}{re+Re} = \frac{R1+R2}{re + R1+R2} = 0.998
So open loop gain
Ao = A1 * A2 = 4.12KV/V
The input resistance
 Rin = {re1 + \frac{R1||R2}{Hfe+1} } = 269\Omega
So after we close the feedback loop the voltage gain will drop to:
Af = Ao/ ( 1 + Ao*β ) = 10.97 V/V
and
Rin_f = Rin* = 101KΩ
Rout_f = (R1+R2) /
(1+ Ao*β) = 29.3Ω But I also not sure about that.
So what do you think about my simplified analysis?
The Following User Says Thank You to Jony130 For This Useful Post:
t_n_k (11-15-2011)
  #9
Old 11-15-2011, 08:07 PM
Default
Thanks for your useful analysis Jony130.
On the matter of which components to include in the open loop AC gain analysis one could perhaps assume that the feedback is 'killed' by shunting Q1 base to ground with a large capacitance. So the DC conditions would be 'preserved' but the AC gain would presumably more closely approach the open loop case.
Would that mean you then dispense with the (R1||R2)/(Hfe +1) term and replace the R1+R2 combination at Q2 emitter with just R2? Presumably yes.
In any event the open loop gain is highly dependent on the Q2 hfe value.
The addition of the load resistance RL to the circuit will also have an effect.
  #10
Old 11-15-2011, 11:41 PM
jegues's Avatar
Default
I think this the source of my confusion.
So the \beta_{1}, \beta_{2} are the transistor current gain beta values NOT the feedback beta factor.
Thanks again!
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Amplifier Feedback Shagon General Electronics Chat 4 06-15-2011 05:46 PM
(PNP) Collector Feedback Bias Amplifier Circuit huntlk Homework Help 1 02-22-2010 08:29 PM
Two stage BJT amplifier with feedback The Electrician General Electronics Chat 57 08-27-2009 04:01 AM
common emitter amplifier circuit using feedback bi den Homework Help 14 03-04-2006 04:58 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
