All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-13-2011, 08:58 PM
wirednuts wirednuts is offline
Junior Member
Default Simple single cell Li-Ion battery charger utilizing NCP1835
its a chip made by On semiconductor and theres still a few left at mouser.
i originally planned on just modifying the existing charger chips inside a cheap charger, but i then figured for $2 i could replace it with a much better solution. im getting a few external chargers that are molded to my cell phone battery, (touch pro 2), and ill remove the internal 350ma charger and replace it with this circuit which is 1000ma.
Features
• Integrated Voltage and Current Regulation
• No External MOSFET, Sense Resistor or Blocking Diode Required
• Charge Current Thermal Foldback
• Integrated Pre−charge Current for Conditioning Deeply Discharged
Battery
• Integrated End−of−Charge (EOC) Detection
• 1% Voltage Regulation
• 4.2 V or 4.242 V Regulated Output Voltage
• Regulation Maintained without a Battery Present
• Programmable Full Charge Current 300 − 1000 mA
• Open−Drain Charger Status and Fault Alert Flags
• 2.8 V Output for AC Present Indication and Powering Charging
Subsystems
• Minimum Input Voltage of 2.4 V Allows Use of Current Limited
Adapters
• Automatically Recharging if Battery Voltage Drops after Charging
Cycle is Completed
• Low Profile 3x3 mm DFN Package
• Pb−Free Packages are Available
http://www.onsemi.com/pub_link/Collateral/NCP1835-D.PDF
as you can see it doesn't take many external parts to make it work, and i guess you can hook it to a microprocessor too for more control. i just want something simple, and after much searching through datasheets, i think this one is the best value.
love to hear any opinions... but the only real question i have is what specific capacitor would be best for the timing circuit?
  #2
Old 11-13-2011, 09:09 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
Did you read the pages 11 and 12 of the datasheet?
The timeout can be set using the Ct.
This is depended on the battery capacity.
Beware that to fast charging a Lithuim battery may result in an exploding battery.
http://batteryuniversity.com/learn/a..._ion_batteries
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 11-13-2011, 09:41 PM
Junior Member
Default
this is for 1500mah batteries, which should be safe to charge at 1a. i will build this so the charger heatsinks close to the battery, that way if the charger or battery gets too warm it will cycle off.
i did not mean what value of capacitor, but if there was a specific kind (ceramic?) that is best for this timer use.
edit- thanks though, looking at things closer i see it would make sense to limit the timer to 140min and change the max charging current to 800ma. i like running things a little under their rating.
  #4
Old 11-14-2011, 12:15 AM
bountyhunter bountyhunter is offline
Default
Quote:
You want a ceramic type "NPO" which is temp stable for an accurate timer. You can also use a poly film type cap.
  #5
Old 11-14-2011, 05:47 AM
Junior Member
Default
well right before you posted that, i of course already placed an order with some basic xr7 ceramic capacitors. they should be fine though, the timeout period is a last-resort fail safe anyway, accuracy is not that important here. i also noticed the variations with temperature are plenty acceptable for my application too....
pretty excited, i have enough parts coming to make 5 of these. if all goes well, i will have one in my room, in my truck, one in my tool bag and one in my laptop bag. i have 2 more batteries coming too for a total of 4... because i genuinely dont like plugging a cord into my phone to recharge it. its much nicer to just pop the battery and stick a fresh one in. plus, this external charger will charge batteries within an hour, not the normal 3 it takes when its in your phone and running all your apps. best part is, this charging chip maintains batteries while plugged in... so i can leave batteries in the charger indefinitely without worry... hopefully....
  #6
Old 11-16-2011, 09:24 PM
Junior Member
Default
ok i guess i forgot to read the part in the datasheet where it says the NCP1835 is too small for any practical purposes...
should i just give up now? is there any possible way i can solder to this chip by hand?
  #7
Old 11-17-2011, 02:30 PM
wayneh wayneh is offline
Default
No and no, IMHO. Live and learn, huh?
Don't give up yet - there are things to allow using surface mount components in thru-hole boards. No idea if anything is available for a chip THAT small, but worth a look. And somebody here might have ideas for you. I can say with 100% confidence that I would have zero chance of soldering that sucker. I'd need dissecting microscope to just see the thing.
  #8
Old 11-17-2011, 05:55 PM
Junior Member
Default
thats pretty much what i thought.
it seems that the only way this is gonna happen is by using soldering paste and a heat gun.
problem is, i dont have a circuit board to stick this thing on. all the tutorials on how to solder these kind of chips show them going onto a circuit board custom made for that chip.
im not looking to make a circuit board for such a simple circuit... and even better is i cannot find any through-hole li-ion IC's like this one. i know they exist, there are shitty ones in these cheap chargers that im trying to mod. if the damn chinese would just put datasheets out for their shitty chips they make, i could probably just mod those circuits to boost the power output a bit (im sure their current is controlled by a resistor just like most others, yet im not in the mood to guess what does what, not with a lithium charger circuit anyway)
this chip was obviously made for a cellphone...
  #9
Old 11-17-2011, 06:06 PM
Junior Member
Default
ARGH you know what, this is really frustrating because its not microscopic small... i can see it.. the pins, they are right there. hello pins just waiting to be soldered. hows it goin? i see you right there in plain sight, and i have no idea how to burn your pads.... this isnt over.
  #10
Old 11-17-2011, 10:24 PM
Georacer's Avatar
Georacer Georacer is offline
Super Moderator
Default
Why don't you buy some solder paste and bake it?
__________________
I am a prisoner of high standards and low social skills
____________________________________
I wish I was the best at what I would do, and what I would do wouldn't be pretty.
Tags
Related Site Pages
Section Title
Worksheet Batteries
Textbook 555 MONOSTABLE MULTIVIBRATOR : 555 Timer Circuits
Textbook Electron activity in chemical reactions : Batteries And Power Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Detecting single cell reversals in long series batteries Mr. Mik The Projects Forum 29 12-07-2010 10:40 AM
Problem with SLA 36 volt battery charger logicrules General Electronics Chat 14 12-16-2009 07:11 AM
Calculating new resistor values for a single cell electrocub The Projects Forum 0 10-19-2009 06:10 PM
Crude Battery Charger DC_Kid The Projects Forum 13 06-04-2009 04:54 PM
Li-ion Battery Charger and Laptops iONic The Projects Forum 7 12-27-2008 10:43 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
