All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-07-2011, 02:04 PM
NewbSolutions NewbSolutions is offline
Default Confusing Clap Switch System
http://talkingelectronics.com/projec...TrCcts.html#37
I'm trying to understand how the circuit works(the clap switch circuit over there) for our basic electronics class but I'm having problems analyzing the circuit, since I don't really understand this part...
"...when a sound is detected, the negative excursion of the waveform takes the positive end of the 10u towards the 0v rail. The negative end of the 10u will actually go below 0v and this will pull the two 1N4148 diodes so the anode ends will have near to zero volts on them..."
...and pretty much everything in the explanation fails to penetrate my thick skull... I have a basic understanding of KVL, BJT analysis and diodes... though not capacitors outside AC circuits... since from my understanding they are supposed to block DC currents? though initially it allows them to pass through until the capacitor gets fully charged, in which case it will then block any more current from passing through... I also think those LEDs have a 10mA minimum current aside from the voltage drop(since they aren't ideal, I think... or is this only for zener diodes?).
also not really sure what happens to the electret mic when a sound is heard, though I think the capacitance of the capacitor hooked to the gate of the JFET changes? or something....
and shouldn't the two LEDs turn on at the start? since they'll pass through 270R, LED, capacitor(while it charges), the base->emitter portion of the BJT(since it functions as a diode if I remember correctly) until the capacitor dies, but then the BJT will then allow current from the collector to emitter for both of them?
I'm not really sure how this works....
and for the assignment, we're supposed to justify the values of the resistors, capacitors... so I'm not sure, though I think the 47k and 33k resistors are there to soak up most of the voltage so the current will be too small to power the LEDs? though not sure what difference the different capacitances of the capacitors do... or what the 270R resistors are for...
sorry, but I'm still very new at this so any help will be appreciated... I'm so sorry for being so inadequate ><
Tags
Related Site Pages
Section Title
Worksheet Junction field-effect transistors
Worksheet Class A BJT amplifiers
Worksheet Bipolar junction transistors in active mode
Worksheet Bipolar junction transistors as switches
Worksheet Bipolar junction transistor theory
Worksheet Characteristic Impedance
Textbook Resonant filters : Filters
Textbook The Shockley Diode : Thyristors
Textbook Resonance in series-parallel circuits : Resonance
Textbook Meter check of a transistor : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
one pulse on switch close, and one on switch open grovecat General Electronics Chat 5 10-23-2011 02:21 PM
Problem with a mic for a clap switch Melawrghk The Projects Forum 4 09-10-2010 04:49 PM
220-240V uC controlled switch falcon74 General Electronics Chat 1 08-27-2010 02:43 PM
3 way toggle switch ron110 The Projects Forum 3 07-05-2009 05:40 PM
SPDT as transfer switch for single phase? notlag General Electronics Chat 1 04-09-2005 04:54 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
